3.5 carbs to 3.9 EFI
Mr Bean
I am thinking of upgrading my 3.5 V8 on carbs to a 3.9 EFI.
I was going to buy a rotten Classic or a Disco as a donor. Hopefully i can find one with LPG at the same time.
The swap of engine and wiring loom seems relatively straight forward but the questions are:
1. Will it fit straight onto the existing 5 speed gearbox?
2. What about the fuel lines and the fuel tank? What tank do i use and do i need to plumb in a return fuel line as well?
Many thanks,
depends on what you want the vehicle for, and what you have or are prepared to pay. The 3.9 and 3.5 efi systems are getting old now and if they give trouble seem to give lots of trouble, though my RRs have been fairly reliable. I intend to take my v8 to places where I wouldnt want to have to walk for help and so simple is better for me. But if it was only an occasional offroader and I could afford the time and trouble for setting up then megasquirt would be the choice.
With any modifications i plan to make i try to keep to keep as many standard parts as possible fpor when i am in remote places parts are easier to come by.
So thats is why i plan on finding a V8 Disco with LPG as swap it all on to my 90 and replace the tired 3.5 with its carbs for something better.
I wouldn't use megasquirt because if I'm in the middle of nowhere parts would be too hard to find.
So you'd use a 20 year old ECU that uses proprietary parts and has minimal support documentation rather than a modern one that uses standard parts available anywhere with circuit diagrams and parts lists & specs freely available? Happy travels! :P
We have some experience of doing this in the opposite direction after a client blew up his 3.9 Efi and we bought a cheap carb 3.5 to replace it. The only real difficulty was replacing the high pressure fuel pump with one from a 110 V8 while keeping the fuel level sensor intact.
With the Efi fuel system you need the high pressure pump and piping from the engine to the tank for the return line.
