DefcoL Posted November 18, 2008 Share Posted November 18, 2008 Hi All, Recently discovered my rear low level winch is in need of a deep hole or a very hot flame. yeah I know explosive is more fun,but cant afford the trouble it would bring... So have been looking to get another 12v for the rear. As there are so many around I wondered what you might recommend. My basic requirements are : Reliability wont take all day to winch up 45degree slope value for money reasonable sized motor.... oh even though I have a second 8274, it wont fit as its too tall. thereby it needs to be low level........................... I also have a hydraulic for the front but nowhere near ready to start pluming yet so for now looking for a bargain. TIA Loz Quote Link to comment Share on other sites More sharing options...
JST Posted November 18, 2008 Share Posted November 18, 2008 TDS - will take all day but it will get you out, very impressed with ours in Holwin Wolf series pulls like anything you just learn to work around the low speed. Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted November 18, 2008 Share Posted November 18, 2008 TDS all the way for a lowline electric that works and keeps on working even when abused somewhat... at a very fair price too! Quote Link to comment Share on other sites More sharing options...
Young bobtail Rhys Posted November 18, 2008 Share Posted November 18, 2008 Another vote for the TDS here Quote Link to comment Share on other sites More sharing options...
ciderman Posted November 18, 2008 Share Posted November 18, 2008 Im a great fan of the 8274 , But as you say Loz you aint got the space , So TDS would be a good choice ,not a comparason by any means but from what ive seen they seem to be very capable units and well priced . Quote Link to comment Share on other sites More sharing options...
Orange Posted November 18, 2008 Share Posted November 18, 2008 What's the reason it won't fit?? Surely if it means modding the frame/tube a bit, the second 8274 will be cheaper as you've already got it... Quote Link to comment Share on other sites More sharing options...
Holyzeus Posted November 18, 2008 Share Posted November 18, 2008 What's the reason it won't fit?? Surely if it means modding the frame/tube a bit, the second 8274 will be cheaper as you've already got it... too tall will stick up out the floor Quote Link to comment Share on other sites More sharing options...
Orange Posted November 18, 2008 Share Posted November 18, 2008 AFAIK it's a trayback Disco......... No floor for it to poke through, unless Lawrence left the floor in.... Quote Link to comment Share on other sites More sharing options...
DefcoL Posted November 18, 2008 Author Share Posted November 18, 2008 TDS - will take all day but it will get you out, very impressed with ours in Holwin Wolf series pulls like anything you just learn to work around the low speed. Hi all thanks for the advice re the TDs, I take it you mean the The TDS -9.5c /12.0c (Goldfish) if so did you go for the 9.5 or the 12? and reasons why? Re: space ; that's my fault for not building enough space to accommodate the 8274 here are some shots to show what I mean. Quote Link to comment Share on other sites More sharing options...
Orange Posted November 19, 2008 Share Posted November 19, 2008 Ah, I see. It's the depth of the tray that won't let you put it in... Just out of interest, Lawrence, why not modify the tray/mounting? Surely it will cost you less than £350 and you then have common winches front and rear so if one breaks... Otherwise, the TDS - I bought one of the early 9.5s. Just keeps pulling and pulling. Bought it cos the 12 wasn't available when I was in the market. Someone will correct me, I'm sure, but I think the difference between the 9.5 and 12 is the gearing, so the 12 will be slower. Quote Link to comment Share on other sites More sharing options...
DefcoL Posted November 19, 2008 Author Share Posted November 19, 2008 Ah, I see. It's the depth of the tray that won't let you put it in...Just out of interest, Lawrence, why not modify the tray/mounting? Surely it will cost you less than £350 and you then have common winches front and rear so if one breaks... Otherwise, the TDS - I bought one of the early 9.5s. Just keeps pulling and pulling. Bought it cos the 12 wasn't available when I was in the market. Someone will correct me, I'm sure, but I think the difference between the 9.5 and 12 is the gearing, so the 12 will be slower. Hi A-O the available space is 625 x 172 x 295. the 8274 really needs a min depth of around 240mm, to alter is more involved than it looks and would necessitate cutting into the original cross member. That will then require getting the stainless box altered thereby altering box mounts. Long term I will be fitting hydraulic that will fit in existing space So will sell the Warns. but mean while I have spares if the 8274 decides to take a vacation.... Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted November 19, 2008 Share Posted November 19, 2008 Just cut out the square cross member from behind the winch and replace with a bit of box in a more convenient spot. We must have moved that cross member 4 or 5 times on Steve's truck Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 19, 2008 Share Posted November 19, 2008 Someone will correct me, I'm sure, but I think the difference between the 9.5 and 12 is the gearing, so the 12 will be slower. Absolutely correct, 254:1 for the 12, and 173:1 for the 9.5. Unloaded feet per minute for the 9.5 is rated at 55.8, and the 12 at 29.3, at 6000lb pull, the 9.5 is 12fpm and the 12 is 7.9fpm. Hope that gives some idea of what you want -I was lucky, I have the 9.5 with a 5.6HP Bowmotor, so should be greater than the above anyhow. Quote Link to comment Share on other sites More sharing options...
DefcoL Posted November 19, 2008 Author Share Posted November 19, 2008 Just cut out the square cross member from behind the winch and replace with a bit of box in a more convenient spot. We must have moved that cross member 4 or 5 times on Steve's truck tea and biscuits or ham sandwich and beer will be on offer Mark. when will you be round with your welder? B) Quote Link to comment Share on other sites More sharing options...
ciderman Posted November 19, 2008 Share Posted November 19, 2008 tea and biscuits or ham sandwich and beer will be on offer Mark. when will you be round with your welder? B) Throw in a gallon of scrump and i might come and help Quote Link to comment Share on other sites More sharing options...
DefcoL Posted November 20, 2008 Author Share Posted November 20, 2008 Throw in a gallon of scrump and i might come and help If I could find a gallon of it round here, I doubt if there would be any left by the time you arrived unless you bring your own. Ah even then there wouldn't be any left on arriva :lol: l Quote Link to comment Share on other sites More sharing options...
JST Posted November 21, 2008 Share Posted November 21, 2008 we are running a 254 ratio one with a Bowmotor on the rear of Rogue Vogue ratios and HP of motors change between the 9.5 and 12 versions. Quote Link to comment Share on other sites More sharing options...
DefcoL Posted November 21, 2008 Author Share Posted November 21, 2008 we are running a 254 ratio one with a Bowmotor on the rear of Rogue Vogueratios and HP of motors change between the 9.5 and 12 versions. Hi James, Ordered the 9.5 Was advised to go for the slower one but then if really stuck will use a block. Might have made a slight mistake but will live with it. Many thanks for the info DB was very good to deal with and it arrived almost before i ordered. Now It will be worth another visit. Quote Link to comment Share on other sites More sharing options...
JST Posted November 21, 2008 Share Posted November 21, 2008 so you have taken the plunge!! i am sure it will be fine - i suggest running less than 100ft of rope on it though to avoid bunching! we went for the lower ratio one as most rear winch use seems to be small pulls at acute angles, dont seem to do much lowering out so thought that was our best bet. line speed didn't seem that much different to the 9.5 either when its all that slow anyway. for the money you cant really go wrong with either. Quote Link to comment Share on other sites More sharing options...
DefcoL Posted November 21, 2008 Author Share Posted November 21, 2008 so you have taken the plunge!! i am sure it will be fine - i suggest running less than 100ft of rope on it though to avoid bunching!we went for the lower ratio one as most rear winch use seems to be small pulls at acute angles, dont seem to do much lowering out so thought that was our best bet. line speed didn't seem that much different to the 9.5 either when its all that slow anyway. for the money you cant really go wrong with either. Very much like the cone brake, saving the plasma burn. It fits with a massive 7mm clearance and if it performs as reliable & speedy as his delivery; I'll be very happy Quote Link to comment Share on other sites More sharing options...
JST Posted November 21, 2008 Share Posted November 21, 2008 in that case i believe you will be happy Quote Link to comment Share on other sites More sharing options...
