white90 Posted December 16, 2008 Share Posted December 16, 2008 12mm on a twin or you'll be buying it again shortly afterward I assure you. buy once buy it right. Quote Link to comment Share on other sites More sharing options...
jacks906 Posted December 18, 2008 Share Posted December 18, 2008 sorry to divert away, but ordered my bow rope today he advised on a 11mm even tho i said was going twin it at some point just going off what was told tho an happy to pop on what they know everyone uses dave Quote Link to comment Share on other sites More sharing options...
white90 Posted December 21, 2008 Share Posted December 21, 2008 Still he'll be ok when you go back to purchase 12 Quote Link to comment Share on other sites More sharing options...
jacks906 Posted December 21, 2008 Share Posted December 21, 2008 suppose so retiar front rope to back when i find an 8274 for there dave Quote Link to comment Share on other sites More sharing options...
90treelad Posted December 21, 2008 Author Share Posted December 21, 2008 12mm on a twin or you'll be buying it again shortly afterward I assure you.buy once buy it right. Chose to go with 12ml bow rope because before i changed to a twin i had never snapped my 11ml bow rope. David Bow attends most of the events that i go to and if there's ever a problem he will always help you out Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted December 21, 2008 Share Posted December 21, 2008 I have a "Interestingly powerfull" Hydro setup, Andy talked me out of 14mm and inro 12mm, and he was right Plasma 12 is the best of the non wire ropes IMHO. Wire is more able to take grief - ie if you drag it in and over ground rocks etc, BUT PITA to use, and shards of wire will go through you gloves and get you Think of Plasma rope as a "Serviceable Item" and you'll be fine, wire rope can eqaully and often is kinked /scrapped 1st time out, so whilst cheaper can maybe hit the bin quicker ? HTH Nige Quote Link to comment Share on other sites More sharing options...
white90 Posted December 22, 2008 Share Posted December 22, 2008 Chose to go with 12ml bow rope because before i changed to a twin i had never snapped my 11ml bow rope. David Bow attends most of the events that i go to and if there's ever a problem he will always help you out Good call! the 12mm is what I'll only buy from now Quote Link to comment Share on other sites More sharing options...
TJ101 Posted December 23, 2008 Share Posted December 23, 2008 12 mm as well, next time i order Quote Link to comment Share on other sites More sharing options...
j90 mud Posted December 24, 2008 Share Posted December 24, 2008 i have to agree we treat our ropes as a service item and wash them, inspect them and bin them if they are knackered.we also turn them on the drum.it does not matter what size of synthetic rope you use it can be snapped very easily.we cut thru 2 plasmas at the baskerville on rocks / debris in the ground on sun at the baskerville event. we have a twin 8274 splitpin winch and plasma 11mm all round and you can almost stall the winch without it breaking as the videos from the event will show. Quote Link to comment Share on other sites More sharing options...
white90 Posted December 24, 2008 Share Posted December 24, 2008 Fair enough I had 11mm on the front single XP motored winch and snapped it 2 or three times at a JST event no debris on the ground a pull at a slight angle(not a long pull) just 20ft or so motor slowed slowed and snap went the rope. since fitting a twin from Jim I thought 12mm was the order of the day and very pleased I did. Quote Link to comment Share on other sites More sharing options...
Dave W Posted December 24, 2008 Share Posted December 24, 2008 Fair enoughI had 11mm on the front single XP motored winch and snapped it 2 or three times at a JST event no debris on the ground a pull at a slight angle(not a long pull) just 20ft or so motor slowed slowed and snap went the rope. since fitting a twin from Jim I thought 12mm was the order of the day and very pleased I did. The only time I've snapped 11mm Plasma 12 like that was 100% down to a worn aluminium fairlead, it allowed the line to make contact with the edge of the hole in the winch mount, a slight uphill angle and it cut through it as soon as it was under tension. I thought I was saving myself some cash by turning the worn fairlead upside down and it cost me a rope instead... Of course there are synthetic ropes and then there are synthetic ropes... if it's not Plasma 12 then, IMV, you're using an inferior product so should expect a few breakages I've also changed to stainless fairleads and have checked and double checked that, regardless of spool position or angle of pull, the rope can't make contact with anything it shouldn't. Quote Link to comment Share on other sites More sharing options...
martin-s Posted December 26, 2008 Share Posted December 26, 2008 whats the best way to put plasma on the drum to stop the snagging and it getting stuck Quote Link to comment Share on other sites More sharing options...
TomG Posted December 27, 2008 Share Posted December 27, 2008 Try and keep the rope under tension as it's being wound on, if it's loosely wound then used under load, the top layer will cut down through. Also heard some folk recommend wind it on at a 30degree angle so it's criss-crossed but not sure if this is correct? I think having a shallower, wider drum with less layers would be less prone to this than a narrow, deep drum. Quote Link to comment Share on other sites More sharing options...
red90 driver Posted December 31, 2008 Share Posted December 31, 2008 Our front 8274 has a 50mm diameter drum, and is 75mm wider than standard. The stainless steel fairlead is setup so that it is 30mm narrower than the drum. we spool on under load but try to criss-cross the rope as it goes on (having a winchman built like a brick khazi helps!) This still does not stop the rope from jamming itself into the lower layers, especially after the first pull of the day. The rear 8274 has a standard drum, but is set right behind the rear bulkhead, with the fairlead in the rear cross member. Having it set this far apart makes the rope spool on loverly. And we don't seem to have problems with the rope cutting through the lower layers. We also use 11mm Plasma from Andy-T, and have not snapped one this year after 6 challenges. Of course, the ropes are washed after every event and then checked for damage. Only had to splice a damaged section once this year, after a recovery over a barbed wire fence! Quote Link to comment Share on other sites More sharing options...
