landrover598 Posted February 2, 2006 Share Posted February 2, 2006 I'm trying to find a computer program and i'm sure someone in here had it It's the one for working out speeds in each gear for different gear box / diff ratios and tyre sizes Anyone know where i can find it tar very muchly Quote Link to comment Share on other sites More sharing options...
western Posted February 2, 2006 Share Posted February 2, 2006 I think Nige [Hybrid from hell] posted something like that or it might just have been a chart. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted February 2, 2006 Share Posted February 2, 2006 Click here to download Numpty instructions: Change the blue values to what you want, red values are the results and green is just some sample data. Quote Link to comment Share on other sites More sharing options...
landrover598 Posted February 2, 2006 Author Share Posted February 2, 2006 Thats the one now i can work out how to make my landy go a bit quicker B) Quote Link to comment Share on other sites More sharing options...
Mark90 Posted February 2, 2006 Share Posted February 2, 2006 Well you're using the wrong type of fuel for a start, and you're down on the number of cylinders Quote Link to comment Share on other sites More sharing options...
landrover598 Posted February 2, 2006 Author Share Posted February 2, 2006 cheeky i want to make it do more than 60 comfortably Quote Link to comment Share on other sites More sharing options...
landrover598 Posted February 2, 2006 Author Share Posted February 2, 2006 Don't suppose you know the R380 ratios ? Quote Link to comment Share on other sites More sharing options...
fruity Posted February 2, 2006 Share Posted February 2, 2006 Don't suppose you know the R380 ratios ? Dave, What tyre/tranny ratio are you using at the mo? Quote Link to comment Share on other sites More sharing options...
landrover598 Posted February 2, 2006 Author Share Posted February 2, 2006 235/85r16 , R380 box and 1.4 transfer Quote Link to comment Share on other sites More sharing options...
Mark90 Posted February 2, 2006 Share Posted February 2, 2006 Gear ratio data Quote Link to comment Share on other sites More sharing options...
landrover598 Posted February 2, 2006 Author Share Posted February 2, 2006 Excellent Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted February 2, 2006 Share Posted February 2, 2006 Thanks Mark, This is really useful. Just absolutely confirmed my decision to go 4 speed (lt95). Quote Link to comment Share on other sites More sharing options...
western Posted February 2, 2006 Share Posted February 2, 2006 (edited) Click here to downloadNumpty instructions: Change the blue values to what you want, red values are the results and green is just some sample data. might I suggest a new thread with the links in it for the Tech Archive Edited February 2, 2006 by western Quote Link to comment Share on other sites More sharing options...
landrover598 Posted February 2, 2006 Author Share Posted February 2, 2006 Well after playing with the numbers, changing to a disco lt230 and 33" tyres may be a bit too high geared I'll see what difference the bigger tyres make first before deciding on changing the box Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 2, 2006 Share Posted February 2, 2006 Hello yes it was me I'll run it for you, it is very very accutae. Need gear ratios 1 2 3 4 5 T Box Ratio High and Low Max RPM Diff Ratios CIRCUMFERENCE of tyres Then give me the options you wnat to try / and or what your looking to achive, I can then prob suggest some options Nige PS Bear in Mind sat and sun Mike wolfe challenege so might be a tad busy / slow ! Nige Quote Link to comment Share on other sites More sharing options...
landrover598 Posted February 2, 2006 Author Share Posted February 2, 2006 Thanks for the offer, but i've got it sused now, from Marks program i just wanted to see how much difference the transfer box and tyre size makes just need to find the money, parts and time Quote Link to comment Share on other sites More sharing options...
Mark90 Posted February 2, 2006 Share Posted February 2, 2006 OOPS sorry Mark didn't remember it was your info/program Well it was Nige's program that has been on here recently, mine was posted a few times in the dim and distant past on LRE board. I'll run it for you, it is very very accutae. Oi what you saying about mine It's as accurate as the data that you put in it, that calculations are correct, although I haven't factored in any slippage in the torque convertor for the auto boxes Quote Link to comment Share on other sites More sharing options...
landrover598 Posted February 3, 2006 Author Share Posted February 3, 2006 I presume the 1.2 box is a straight swap for a 1.4 box ? or did land rover in their wisdom make them completely different Quote Link to comment Share on other sites More sharing options...
Mark90 Posted February 3, 2006 Share Posted February 3, 2006 Aye straight swap Except possibly for the handbrake cable bracket mounting holes are different between the RR and defender setups. Nothing to trouble a chap of your abilities Quote Link to comment Share on other sites More sharing options...
landrover598 Posted February 3, 2006 Author Share Posted February 3, 2006 B) Excellent I've got one of those fantastic disk handbrakes so no problems with the brackets Quote Link to comment Share on other sites More sharing options...
