Tangoman Posted December 18, 2008 Share Posted December 18, 2008 Hi all, Need some advice 90 300tdi since i bought it it has never really smoked but now on start up it is throwing out a lot of blue smoke but when it starts to warm up it clears and doesen't smoke at all. Your diagnosis would be much appreciated. apart from Will Warne sorry Will Quote Link to comment Share on other sites More sharing options...
white90 Posted December 18, 2008 Share Posted December 18, 2008 Check the turbo spindle for anthing more than a mil or two of freeplay blue smoke=burning oil, so oil is getting into the intake/cylinder somehow. you could pull the glow plugs to see if any are excessivley oiled. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted December 19, 2008 Share Posted December 19, 2008 When my car first smoked "blue", I had to erase and rewind my thoughts. DOH .. I had filled almost 80 litres with PETROL... Sure landy is a diesel 110 99 model... Maybe you got traces of petrol in the diesel tank? Quote Link to comment Share on other sites More sharing options...
Jon W Posted December 19, 2008 Share Posted December 19, 2008 Check the timing. My timing had moved and it was causing lots of bluey white smoke on start up as it was obviously fueling at the wrong time. Jon Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 19, 2008 Share Posted December 19, 2008 Valve stem seals are another possibility I think Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 20, 2008 Share Posted December 20, 2008 Glow plugs not working will cause a puff of smoke on start-up, but only for a few seconds and then not at all for the rest of the day until the engine has been switched off for several hours. Worn stem seals or guides will let a small amount of engine oil to drain into the cylinder from the head overnight and cause the same thing. Briefly revving the engine at any time - hot or cold and getting a puff of smoke is a typical symptom of worn stem seals or guides. Retarded timing will cause grey-ish smoke on start-up (identified by intermittent puffs), which gradually goes as the engine warms up. You can identify the smoke by smelling it. Les. Quote Link to comment Share on other sites More sharing options...
