hattymender Posted December 26, 2008 Share Posted December 26, 2008 The little hole found by the MOT man before Christmas got some attention today (her family turned up, so I decided I'd rather spend the day under a car welding ). But the 'little hole' is now as big as a badger set with no sign of 'honest metal', think my hammer's bigger than the MOT one. So she's for the scrap man . What to salvage from a 1.8 Zetec for 'project V8'? Coils and crank sensor? Start of megajolt project? Battery? Could run auxiliaries via split charge? Seat belts? Always needed 'cos Defender doors eat them. Relays? Intermittent wipers? Door lock solenoids? Speakers? Alternator? They can be adapted for V belt? Suggestions? Quote Link to comment Share on other sites More sharing options...
edwardatherton Posted December 26, 2008 Share Posted December 26, 2008 Coils and crank sensor? Start of megajolt project?Battery? Could run auxiliaries via split charge? Relays? Intermittent wipers? Speakers? Alternator? They can be adapted for V belt? Yep, ignition parts should be kept, as should the battery (always handy to keep charged for jump starting purposes). Relays, fuses, wire etc are handy, speakers are useless (when, they are in my S1 or wife's Fiat 500!). Alternator, starter motor, tyres, wheels etc could be sold on if not needed for LR use. Quote Link to comment Share on other sites More sharing options...
SiWhite Posted December 26, 2008 Share Posted December 26, 2008 I always keep fuses and relays for Landy use. Gas struts could be good for a project, especially if they're small. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 26, 2008 Share Posted December 26, 2008 Relays, fuses, coil pack, mount, & connector, HT leads, VR sensor, EDIS-4 unit if it has one (no use for a V8 but you may well be able to flog it to someone doing an MS/MJ project on a 4-pot), injectors if it has 'em, idle control valve if it has one that's usable, alternator, lambda sensor, cooling fans, battery, seats if you've got a use for 'em, carpets can be handy for the workshop floor. Quote Link to comment Share on other sites More sharing options...
bluespanner Posted December 27, 2008 Share Posted December 27, 2008 Rip out the engine and box Mount it longitudinally in an 80" chassis, where the passenger seat should be Weld prop shaft flanges onto the driveshaft ends and bolt to diffs Dumper tyres Off you go! Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted January 10, 2009 Share Posted January 10, 2009 Hi Having just had a serious sense of humour failure in the scrapyard I'd be interested in your edis unit if you have one Ta Mike Quote Link to comment Share on other sites More sharing options...
SteveRK Posted January 10, 2009 Share Posted January 10, 2009 Ignition, door and fuel filler locks are worth salvaging as older Ford's being ford's often get targeted by opportunist filth/scumbag thives for the 50pence left in the glove box- and if memory serves me correctly the locking key barrel assemblies wear badly so you wont have a problem selling them. The gearlever with its fittings are also notorious for wear and sloppy seconds' and have a value Quote Link to comment Share on other sites More sharing options...
Dunc Posted January 10, 2009 Share Posted January 10, 2009 Keep the washer bottle because ford ones normally have a pump mounted to the bottom of them and they're dead handy for MOT problems or project builds. My mate in Devon could probably do with your engine too, but it's a long way for him to push his wheelbarrow! Quote Link to comment Share on other sites More sharing options...
