Core plugs
steve_d
That's because they are not intended as expansion plugs.
They are there to fill holes left during the casting process.
Some also to fill holes used for machining operations.
Better explanation at http://www.mgaguru.com/mgtech/cooling/cool_105.htm
Keep your fingers crossed that you have no damage. VERY common in this last bit of cold weather as everyone is used to the mild winters we've had & hasn't bothered doing the antifreeze. Not a good idea as it also protects against internal corrosion
The recent sustained freeze has caught a lot of people out who didn't have enough/any anti-freeze in their motors. I repaired a K-series engine the other day that had sheared the impellor off the water pump because of internal ice. The engine would overheat within a couple of minutes and it was still being driven. Still - that'll be a head gasket to do soon :)
Les.
Popped a new plug in but water now floods out down the back of the engine but can't see from where. Suspect it is the heater pipes that run under the intake as they were looking a bit rusy last time the inlet was off.
So this just brings forward the install of the MS 3.9 which is ready on the engine stand.
Ho hum
Steve
Agreed - welch plugs are not there to pop out, but to fill the holes.
If you have a Tdi and run it without antifreeze the core plugs will rust through and your engine will be stuffed unless you have a coolant level sensor fitted. Reconned an engine last month. The water pump and the internals of the block looked a sight to see. Owner thinks it doesn't get cold in SA, and he was right on that score.
If you have a TD5 and run it without antifreeze the oil cooler will corrode through (I've seen three now) and the oil at 4 bar or so will go into the coolant which is at 1 bar. Makes a mess, but not the end of the world if you catch it before the engine runs out of oil. On the TD5 head the coolant channels are VERY close to the bores so you are asking for blown head gaskets in the future if they get corroded.
