gaz0203 Posted January 30, 2009 Share Posted January 30, 2009 just been tuning my disco using info found on this site and i must say.. what a difference!! ive been inside the pump and done the necessary adjustments. ive also fitted a boost gauge, upped the boost slightly, fitted a set of high clones, and fitted a front silencer replacement pipe, my question is im toying with the idea of putting a performance air filter in but am not sure whether this will make any difference, any body had any experiences with this? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 31, 2009 Share Posted January 31, 2009 Jim Attrill has Somewhere on here are some nice photos of what a certain well known brand of performance air filter does to your engine in dusty conditions... Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 31, 2009 Share Posted January 31, 2009 Here you go http://forums.lr4x4.com/index.php?showtopic=17362 http://forums.lr4x4.com/index.php?showtopic=33385 Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted January 31, 2009 Share Posted January 31, 2009 Thanks for posting that Steve - saved me the effort. I should mention that the unmentionable 'filter' was fitted from 80-166 k kms with the damage as shown there. I was not very rich at the time so honed the bores a bit and fitted new KS rings and a paper air filter. The engine is now at 275k kms and starts perfectly and goes well. Sometimes a bit of smoke when cold, but that's it. Quote Link to comment Share on other sites More sharing options...
gaz0203 Posted January 31, 2009 Author Share Posted January 31, 2009 was this an open filter or element? Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted February 1, 2009 Share Posted February 1, 2009 It was a KanNot™ filter, specially made for the 300Tdi Defender casing. It said it was made in the UK rather than the US. It looks rather like the paper element type. The only difference is that it doesn't filter anything so you might as well run with no filter at all. You can get away with that in the UK, I used to run motorbikes with alloy venturis and no filter at all. I've still got the 'filter', don't know why really. Can post a foto of it if you want one. I thought of fitting it to my lawn mower, but that died and now I have an electric one. Quote Link to comment Share on other sites More sharing options...
africanpete Posted February 1, 2009 Share Posted February 1, 2009 Gents, what do you think of the ITG filters? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 2, 2009 Share Posted February 2, 2009 No experience of them but probably similar strengths and weaknesses. Jim your electric lawnmower should be fine with a K&N and will last for years Quote Link to comment Share on other sites More sharing options...
discomikey Posted February 18, 2009 Share Posted February 18, 2009 ive only adjusted the torx screw so far and that has helped with my lower end power before the boost, and i am going to do the star wheel one tomorrow, the thread telling how is a little confuzing IMO though. mikey Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 18, 2009 Share Posted February 18, 2009 Which thread? Easy enough to do anyway, take the four screws out and remove the top from the diaphragm unit, note EXACTLY where the tick mark is on the metal centre of the diaphragm (best thing is to mark a line with a marker pen across the rubber and onto the metal body) and then pull that out. Turn the starwheel the required amount, refit the diaphragm in the same position and pop the top back on. Quote Link to comment Share on other sites More sharing options...
discomikey Posted February 19, 2009 Share Posted February 19, 2009 Which thread?Easy enough to do anyway, take the four screws out and remove the top from the diaphragm unit, note EXACTLY where the tick mark is on the metal centre of the diaphragm (best thing is to mark a line with a marker pen across the rubber and onto the metal body) and then pull that out. Turn the starwheel the required amount, refit the diaphragm in the same position and pop the top back on. oops, i forgot to mark the diaphragm unit, which might explain my problem now i was fiddling with the star wheel, and iturned it 1 turn clockwise, an improvement by a small amount, so i turned another full turn, big improvement with the boost but before the boost i have no power, its worse than before i even touched the smoke screw, and it was putting out a lot of smoke when flooring it and when holding at full throttle, so i turned down the smoke screw, which had little effect. also when i completely dropped off the revs the engine juddered as if on the edge of stalling, so i sorted that with the power screw, but still no take off power and a lot of smoke, i decided to turn the star wheel back by half a turn and see what happened, slightly less power and smoke, but still no power when pulling away, can anyone give tips? mikey Quote Link to comment Share on other sites More sharing options...
muddy Posted February 19, 2009 Share Posted February 19, 2009 I only ever bother to turn the diaphram, gives the you the fuel on boost when you want it. Quote Link to comment Share on other sites More sharing options...
discomikey Posted February 20, 2009 Share Posted February 20, 2009 ahhah got it perfect, turned the diaphragm 30 degrees A/C then fiddled with the smoke screw and power screw jobs a fish as we say here in deepest derbyshire mikey Quote Link to comment Share on other sites More sharing options...
