radio upgrade
dicsosfa
hello to all :)
Q1 . looking to upgrade from my radio/cassette to a cd player,
i have a 300tdi disco with with radio controls on the facia behind the steering wheel
question is can i still use these with an after market unit or can i just not connect them up ?
Q2. one of my headlamp washers has been broken off ,as they never worked can i just remove the last one and block the pipe off at the tee piece behind the valance ?
thanks <_<
in answer to question 2 Yes
can`t help with question 1, sorry
Re question 1 - this is possible, depending on the new unit you buy. The controls just plug into the back.
If you don't HAVE to have them, you will find a wider range of units available.
Can I suggest you have a look at DAB radio? I found DAB on Wheels (click here) really helpful and bought a great CD/DAB/FM/Bluetooth unit and arial for much less than I expected.
HTH
