Badger90 Posted April 15, 2009 Share Posted April 15, 2009 whats the best way to get bearings off without a puller.. tryed smacking them with a hammer now iv hit a tooth and chiped it :angry: id rather avoide this misshap is anyone knows a better none pikey way of doing.. cheers sam Quote Link to comment Share on other sites More sharing options...
cipx2 Posted April 15, 2009 Share Posted April 15, 2009 Was that one of your teeth or Pikey's? It would help to say which bearings are you talking about. The ones on driveway gate? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted April 15, 2009 Share Posted April 15, 2009 Are they blind bearings? taper? radial? Quote Link to comment Share on other sites More sharing options...
steve_d Posted April 15, 2009 Share Posted April 15, 2009 If I were to assume you mean a bearing inner race stuck on a shaft then put a diagonal cut in it with an angle grinder then drive a chisel into the cut. Steve Quote Link to comment Share on other sites More sharing options...
simonr Posted April 15, 2009 Share Posted April 15, 2009 Are you doing it without a puller because you don't have one - or because there is no access? You can sometimes exert enough force by hammering a chisel in behind the bearing. Si Quote Link to comment Share on other sites More sharing options...
Badger90 Posted April 15, 2009 Author Share Posted April 15, 2009 carp sorry chaps.. CIPX2: no its a tooth off a input gear.. i didnt put that in the note Anderzander: i have no idea what bearings.. but there off a input gear off LT230 steve_d: cheers steve will try that one.. simonr: im doing it with out a puller because i do not have one amd i hae tryed smacking it with chisel and hammer but no joy but ill try what steve said with the grinder.. cheers boys.. i can get on with my re-build now Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted April 16, 2009 Share Posted April 16, 2009 go and buy a puller, they aren't too expensive! Mike Quote Link to comment Share on other sites More sharing options...
jil6939 Posted April 16, 2009 Share Posted April 16, 2009 Running a bead of weld around the bearing sleeve works very well. Quote Link to comment Share on other sites More sharing options...
roguevogue Posted April 16, 2009 Share Posted April 16, 2009 If you don't want the bearing then grind through the shell. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted April 16, 2009 Share Posted April 16, 2009 Or whack it to pieces!! Quote Link to comment Share on other sites More sharing options...
