92.9 Posted June 16, 2009 Share Posted June 16, 2009 I expect this is a stupid question, but can you fit a full soft top to a high-capacity pick up? Obviously there is a width difference, and of course the gap between the cab and the pick-up section, but nevertheless I would be interested to know if a soft top exists for this type of vehicle. I have had a search around, but couldn't find anything. Mike Quote Link to comment Share on other sites More sharing options...
Philip Tonkin Posted June 17, 2009 Share Posted June 17, 2009 I know of nothing that exists but can see no reason it couldn't be made. Like the Lara Croft film defender but with a full tilt. Quote Link to comment Share on other sites More sharing options...
darkman Posted June 17, 2009 Share Posted June 17, 2009 You could probably fit a soft top truck cab with series 2 doors. Quote Link to comment Share on other sites More sharing options...
92.9 Posted June 17, 2009 Author Share Posted June 17, 2009 Thank you both. I hadn't seen the Lara Croft Defender, but have just looked it up on Google. It looks good, but not quite what I had in mind! I like the Series doors idea though, to get the removable door tops. What I had in mind was just a standard type full soft top. I know you can get soft tops for the High Capacity pick up bed, so maybe one could be adapted to incorporate a truck cab soft top. I'm just thinking how the cab-to-pick-up bit would work, with regard to the framework. Mike Quote Link to comment Share on other sites More sharing options...
Poptopshed Posted June 17, 2009 Share Posted June 17, 2009 127 Rapiers had a hood for the cab that then widened and went higher to cover the bigger back body. You could possibly adapt one of these if you can find one. Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted June 17, 2009 Share Posted June 17, 2009 Not a great pic but... I would think it would be fairly easy to join a normal full tilt and a hi-cap back tilt to get what you want. Will Quote Link to comment Share on other sites More sharing options...
92.9 Posted June 18, 2009 Author Share Posted June 18, 2009 Thanks Will and Poptopshed. I forgot all about the Rapiers. That shouldn't be a problem then. Mike Quote Link to comment Share on other sites More sharing options...
Eightpot Posted June 18, 2009 Share Posted June 18, 2009 I could well be wrong, but I think there is a truck cab rapier version as well with a seperate tilt which should be just the job - if it's not a figment of my imagination.. Quote Link to comment Share on other sites More sharing options...
92.9 Posted June 18, 2009 Author Share Posted June 18, 2009 I'll look out for that. Don't think I've seen one of those. Since I last posted I did find a very nice one-off conversion on East Coast Rover's website. It's a separate truck cab soft top and rear High Capacity 3/4 soft top. Not quite what I was thinking of, but looks really nice. It has the Series doors to get removable door tops as well, which looks quite good with the roof off. Mike Quote Link to comment Share on other sites More sharing options...
