Voltmeter question
bishbosh
Right.
I have a 12V voltmeter (VDO) that I intend to wire across the terminals of one of my two batteries. These two batteries are normally wired in parallel so I should get an acceptable reading right?
However, I will shortly be installing a box of tricks from Mr Bowyer that will switch the batteries from parallel to series to generate 24V for my winch. Rest assured (says Mr Bowyer!) this will not change all the vehicle electrics to 24V, only the winch circuit.
So, am I right in saying that when in 24V mode the voltmeter will register the voltage of one of the batteries only? This is what I want so I can be sure it doesn't get dragged down too far by the 24V switch (alternator won't keep up).
Ta,
Bish.
I'm sure that will work perfectly.
Not sure I'd put the batteries under my seat with that setup though.
And I might invest in a decent fire extinguisher. :ph34r:
PMSL :rofl:
I read Turbochargers reply and was about to post an answer when I read that ^^^
Nicely put :lol:
