bishbosh Posted June 23, 2009 Share Posted June 23, 2009 OK folks, I have an 80psi VDO sender. Thread looks to be M14, but it is tapered so perhaps not? Stamped on the flats of the hex nut are: 8 +- 2lbs /sq inch - this is self explanatory I think 30/20 11.99 The sender has two "outputs". The casing adjacent to each is marked "G" and "WK" Can anyone positively identify it please? Thanks, Bish. Quote Link to comment Share on other sites More sharing options...
western Posted June 23, 2009 Share Posted June 23, 2009 could be 8psi +/- 2 psi 11.99 looks like a makers build date code [Nov 1999] G may be = gauge WK may be = Warning light does it look like these https://www.europaspares.com/INSTRUMENTS/SE...NDERS_5030.html Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 23, 2009 Share Posted June 23, 2009 the G and WK markings are the same as the ones on my ebay special oil pressure sender. G is ground and WK is signal. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 24, 2009 Author Share Posted June 24, 2009 Ralph, Yes, it looks like those but with two terminals. What I really want to know is the thread so I can work out how to connect it to my 200TDi. I have a feeling that the 30/20 relates to that but I cannot find reference to it. (Plenty of others, like 26/23 etc) Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 24, 2009 Share Posted June 24, 2009 These sensors are often 1/8" NPT but that looks more like M10 than M14... Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 24, 2009 Author Share Posted June 24, 2009 The one I have looks like the one Ralph linked to, but it is not that exact model. The threads on mine are almost exactly 14mm diameter but are tapered....... Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 24, 2009 Share Posted June 24, 2009 1/4" NPT is 13.7mm OD, and should have 18 TPI Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 24, 2009 Author Share Posted June 24, 2009 Ah ha! And there's me thinking a quarter of an in was six and a bit mil...... How silly of me!!! Looks like it is 1/4" NPT then. Thanks a lot! Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 24, 2009 Share Posted June 24, 2009 ye its rather random! No idea where the sizing comes from! Quote Link to comment Share on other sites More sharing options...
western Posted June 24, 2009 Share Posted June 24, 2009 I think NPT threads are a US version. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 24, 2009 Share Posted June 24, 2009 Wiki knows all Quote Link to comment Share on other sites More sharing options...
justustwo Posted June 24, 2009 Share Posted June 24, 2009 Sorry if this is hijacking this thread but is very related topic.....does anyone know what type of vehicles would use a standard VDO pressure sender like the one in the pic.I need one around 5 bar but could also be useful at 10 bar(plan to use one as back up to mechanical one on my Toyota engine series 3 and one for the on board compressor measuring-Ive already got the gauges). The new ones are crazy prices and I am sure must be able to get them in a scrappy but not found anything yet...if I knew what cars would have suitable VDO senders that would be a help...ps I am inSouth Africa so must be something common Quote Link to comment Share on other sites More sharing options...
western Posted June 24, 2009 Share Posted June 24, 2009 the maybe fitted to some of the German made cars, Audi, Mrec & BMW as original manufacturers parts, most vehicle makers buy parts like that in rather than make their own. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 24, 2009 Author Share Posted June 24, 2009 OK, so it looks like the pressure sender is 1/4" NPT male. So how do I connect it to the 200TDI then which I understand (from using the search function :P ) is M10 x 1. Lots of googling has failed to find an adapter to suit or even a combination of adapters. Don't really want to buy a new sender (got this one cheap as part of a job lot from on here a while back ) as they are nearly £40! I would also like to keep the dash warning light too, just to complicate things!! Quote Link to comment Share on other sites More sharing options...
western Posted June 24, 2009 Share Posted June 24, 2009 may be able to convert the adaptor I used to fit a oil pressure gauge on my 200Tdi. as here Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 24, 2009 Author Share Posted June 24, 2009 Yes - studied that thread with interest (searched you see ) but I don't think the adaptor will receive effectively an M14 when it is made for an M10! I think it is either a custom T adaptor (1/4" NPT female one end, M10 female another and M10 male on the other) or a new sender I might be able to simplify it by using the blanked position for the warning light so I just need 1/4" NPT to M10......... anyone...? Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted June 24, 2009 Share Posted June 24, 2009 Sikaflex? :) Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 24, 2009 Share Posted June 24, 2009 it is quite an odd size as most are 1/8". The sensor i fitted to the A4 for oil pressure utilised a "T" piece, with male and female M10's and a 1/8" NPT on the side for the sensor. Perhaps one of these T's plus a 1/8" -> 1/4" NPT adaptor? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 25, 2009 Author Share Posted June 25, 2009 it is quite an odd size as most are 1/8". The sensor i fitted to the A4 for oil pressure utilised a "T" piece, with male and female M10's and a 1/8" NPT on the side for the sensor.Perhaps one of these T's plus a 1/8" -> 1/4" NPT adaptor? My thoughts exactly, but I cannot find the reducer from 1/4" NPT to 1/8" NPT. I shall try and call around today..... Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 25, 2009 Share Posted June 25, 2009 It might be easier just to get another sensor? My oil pressure gauge was about 20quid from ebay, and came with the appropriate sensor. Quote Link to comment Share on other sites More sharing options...
