3 Phase Generator for 3Ph Welder?
Warthog
Morning Gents,
Looking at 2nd hand 3 Phase welders at present, but not having a 3 Phase supply has led me to looking at 3Ph Generators. Theres a few about, that are reasonably priced at around the 6Kva power rating (5.5Kva Continous) With the capability to run sensitive equipment on them.
Am i being too optimistic, to think this power output. Would cope with say 250amp max for AC tig?
Cheers
Mark
What is the power requirement of the welder?
My limited experience of welding off generators is that you really want a decent genset bigger than the "theoretical requirement" of the welder i.e. if your welder needs 5KVA then you probably need an 8-10KVA generator to be comfortable - welding has huge fluctuations in the current draw as you will see if you weld on the same circuit as there are lights switched on - they flicker like hell as the AVR in the genset struggles to keep the voltage steady. I don't know but I strongly suspect that the peaks require a set with a higher max output - and AVRs don't really like welders either so running a set near its max capacity may end up with you needing a new AVR at some point - and they ain't cheap (the ones in our Lister HR/TS are about £350 odd I think!). I think you'll find that the proper industrial sets like Listers may cope better with this sort of load than a made in China jobbie - we used to run the farm's arc welder off a 7KVA Lister TS2 and it worked OK but that was only about 150 amp. I'd suggest it might be better to get a second hand decent set than a new cheapo one.
I have a cheapo Hyundai single phase genset (this one) to run a house I am doing up at the moment, but I don't think I'd try welding off it :unsure:
Just my 2p, not so much as a welder but as somebody who grew up living off diesel generators - no mains power out in the sticks down here!
Tig sets require a nice steady power supply. In my experience running a high amperage set of a genny will cause the set to fail.
So set are "gen safe " but not the best.
Whats wrong with a 240v set apart from cost!?
Your right there :blink: The price you pay for a 240v set is silly money.
Hav'nt found a 240v set that has "Continous HF" on it?
Why do i want continous HF? Its what i use at work on Alluminium, and it makes life alot easier :)
We got an ACDC migatronic Pi 200 thats 240v. $$$'s for sure.
Whats continuous HF? You mean a latched button? By nature the current switches between ac/dc so i'm stumped.
I have the option on my TIG machine to switch the HF to Off, Start or Continuous. With the HF set to start, it will activate to establish a weld pool, and then stop - used for DC welding - set to continuous, you get HF all the time, helping to restablish the arc after every switch of polarity (ie on AC welding). Off is used for arc welding.
Mark
I don't know anything about generators, could you run an old transformer
welder[tig] off one? I was wondering about the unbalanced load with only two phases being used.
HF continuous on my welders has mean't it works continuous on AC, but stops after arc starting on DC.
I ran a 300 syncrowave at home on domestic supply.
Mark
No such option here...fully auto on the PI! Self senseing even down to polarity so now need to swith the pos and neg around on the front of the set! I have been spoiled.
Most new ,decent, TIG sets are fully auto now. Tried the Kempiis aswell but price has alot to do with most purchases i beliveve.
Some ggod second hand, read repossed, plant around at the mo. Try some of the online plant sales auctions.
What you need to run a 3ph Tig set is a big old set with a transformer type AVR,I've been through the niceties of wrecking electronic ones - I now have a hybrid one with "Extra frontal suppresion" and I have a balanced 1Kw load across each phase all the time to flatten it all off.
My Tig is a Thermal Dynamics 300A AC/DC set which runs off the 3 phases and the HF goes off automatically on AC once it has established the arc - it is supposed to give a better weld.Most early sets only run across 2 so you need to be careful not to overload the two you end up using.I think this has also wrecked a few genny's as well as the HF spiking back up and trashing thew AVR.
Whats really nice is to have a slow running 6 cyl Gardner or similar and a sodding great old GEC alternator - last forever.
Maybe im a little behind whats available?
The Fronius/Lincoln sets that i use at work are silly money (5K+) But all have Continous HF. When trying to weld Ally without it, seems pretty awkward, if your electrode drifts away from the weld pool for a split second. The Cont HF, seem to just ease that? Maybe im just carp at it :(
Maybe i need to look into all the new technology available using a 240 single phase set?
My heads spinning........cheers for the reply. This subject is mine field (head spinninig)
Cheers
Mark
what about using a rotary phase convertor rather than a inverter type?
Not sure how exactly the TIG would like running from a rotary convertor, but they're pretty cheap to setup and get reasonably big power outputs from.
(from my understanding you can basically build one yourself using a big 3 phase electric motor and some gubbins to get it spinning)
Cheers
Mark
If your down pop in and have a play.We have a Migatronic PI 200 acdc 240v set which we use exclsively for alloys. My fave is the 300 amp synergic MIG. It will even pulse in a bead to look like TIG work!!!! great for land rover Fabs :ph34r:
http://www.migatronic.com/default.aspx?m=2&i=171
