bishbosh Posted August 9, 2009 Share Posted August 9, 2009 I am looking for a couple of storage boxes to fit into the back of the 90. Ideally, they would be about 300(W) x 400(D) x 150mm (H). Only need them for shackles, strops and snatch blocks etc. I want them to sit on the rear floor just inside the rear door, one each side of the fairlead for my rear winch. The top of the box must be below the wheel box height. Ideally the lid should be hinged on the short side. I was thinking of a plastic tool box or ali storage box but I have googled and fleabayed and not turned up anything that catches the eye. I know I could make something out of ply, but I really want something better than that (or a cut down ammo box TBH). So, before I get a quote from Jez for some blingness , anyone got any off the shelf solutions? Oh, and they need to be cheap too!! :D Quote Link to comment Share on other sites More sharing options...
Dave W Posted August 9, 2009 Share Posted August 9, 2009 I keep all my shackles, snatch blocks etc... in an ammo box, they are cheap, robust and water tight. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted August 9, 2009 Share Posted August 9, 2009 Have a look at Solent Plastics - http://www.solentplastics.co.uk/stacking-p...ontainers-boxes Their Euro Stacking range has - 21010 - 400 x 300 x 118 21027 - 400 x 300 x 175 20028 - 600 x 400 x 150 or, under 'Special Offers' http://www.solentplastics.co.uk/special-offers - SP6413 - Stacking Heavy Duty Tidy Tray with 5 Removable Compartments Size (Ext): L 600 x W 400 x H 145mm Size (Int): L 555 x W 355 x H 130mm Desc: Ideal as a tray for all small parts: gardening, under sink, shed, garage, modelling, crafts, DIY. Blue, Heavy Duty. Solid sides and base. Handgrips. Standard Euro Size. 5 x Modular Stackable inserts: 2 x L 135 x W 85 x H 107mm, Grey. 1 x L 542 x W 170 x H 107mm, Orange. 1 x L 270 x W 170 x H 107mm, Green. 1 x L 170 x W 135 x H 107mm, Brown. Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted August 9, 2009 Share Posted August 9, 2009 Wolf box? Gommo box? Quote Link to comment Share on other sites More sharing options...
leeds Posted August 9, 2009 Share Posted August 9, 2009 As Dave said ammo boxes (steel) are cheap and waterproof around a fiver Believe Wolf Box is a South African Army ammo box costs around £25 Go to your army surplus store and have a look for ali tool boxes. Got some about size of a wolf box these are robust reasonably dust and water tight. Have one bolted down in back of hybrid with recovery gear etc in Brendan Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 9, 2009 Share Posted August 9, 2009 I don't think you'll get much in a compact box Bish, they're quite flat and round. Try and get a shackle in the one from the wife's handbag, you'll see I'm right Ah, my coat ... Quote Link to comment Share on other sites More sharing options...
