macandrc Posted August 12, 2009 Share Posted August 12, 2009 Evening all, i have a 200tdi defender engine trnsplanted into my old TD 90, it runs very well but i struggle to get above 60 and it doesnt pull that well up hills, is this normal? could this be because i still have the 1986 TD gearbox fitted? what would you all recommend? fit a larger intercooler and different transfer box? colin Quote Link to comment Share on other sites More sharing options...
western Posted August 12, 2009 Share Posted August 12, 2009 wll be the almost same gearing as a 200tdi factory vehicle, check the throttle cable adjutment, the plastic knurled nut sometimes moves on the cable & can affect the throttle position & range of movement of the throttle arm on the pump. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 13, 2009 Share Posted August 13, 2009 wll be almost the same gearing as a 200tdi factory vehicle, check the throttle cable adjutment, the plaqstic knurled nut sometimes moves on the cable & can affect the throttle position & range of movement of the throttle arm on the pump. Theres a slightly lower ratio on 5th on the LT77 fromt he TD compared tot he tdi LT77s. This shouldnt make a huge amount of difference though. Is your lift pump working correctly? I'd check the throttle cable movement first as Ralph suggests then think about changing the fuel lift pump. It worked on mine and i think the pump was partially working. Everything else felt ok, just a rubish top end. didn't notice any difference in my 110 [previously fitted with a TD] & the new 200tdi Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted August 13, 2009 Share Posted August 13, 2009 Have you checked the boost? Mine was very similar when mine was down on boost. Quote Link to comment Share on other sites More sharing options...
KAD508X Posted August 14, 2009 Share Posted August 14, 2009 Try checking the hose connections to turbo to intercooler. Quote Link to comment Share on other sites More sharing options...
mick110 Posted August 14, 2009 Share Posted August 14, 2009 Try checking the hose connections to turbo to intercooler. .......also try swilling out i/cooler with solvent? Quote Link to comment Share on other sites More sharing options...
