bishbosh Posted August 25, 2009 Share Posted August 25, 2009 I have heard from many that the freespool of the TDS is wonderfully smooth and easy to pull out the rope. Well, mine isn't! It is vein popping hard work to pull the rope out and the winch is brand new. I thought it might need bedding in so it had a serious workout this weekend but that didn't improve things. The winch tray is not warped - it is one piece and press-brake folded out of 8mm steel with a lip at the back. Anyone got any clues? Quote Link to comment Share on other sites More sharing options...
landrover598 Posted August 25, 2009 Share Posted August 25, 2009 Are the bolt holes square on the winch tray ? Try undoing diagonally opposite bolts and see if it's any better as the rope should indeed come rolling off one handed. Quote Link to comment Share on other sites More sharing options...
white90 Posted August 25, 2009 Share Posted August 25, 2009 Mine was similar and the winch was out of square by a very minimal amount one sorted the freespool is fine Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 25, 2009 Share Posted August 25, 2009 Ones a one handed job, not one finger as advertised, but not bad, certainly easier than a mates Superwinch lp8500 or whatever it is... it did get a bit easier after use. Makes me wonder how square my holes are now... Quote Link to comment Share on other sites More sharing options...
stewy1984 Posted August 25, 2009 Share Posted August 25, 2009 Mines like that bishbosh. It's like a tug of war. My freespool lever doesnt click in either unless you pull the rope to move the drum. i'm putting it down to my home made mount being sligtly out, but have yet to try it on the back, witch has a bought winch mount. Quote Link to comment Share on other sites More sharing options...
bobtail4x4 Posted August 25, 2009 Share Posted August 25, 2009 Mine literally is a one finger job, it pulls out so easily and fast, i am still so pleased with it, after the ramsey died, I would check that its mounted flat as said. Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted August 25, 2009 Share Posted August 25, 2009 Mine is a one finger job too, that is with synthetic rope mind....ive no idea if its more difficult with the wire. Dave. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 26, 2009 Author Share Posted August 26, 2009 Thanks folks. Tony / Dave, would you be so kind as to expand on the out of square business? I removed the wire rope before the winch was ever fitted to a bumper and it was still really difficult to turn, so I don't think it is caused by being bolted down funny. I will of course try the suggestions above just in case, probably at the weekend... Quote Link to comment Share on other sites More sharing options...
white90 Posted August 26, 2009 Share Posted August 26, 2009 My rear winch is fitted to a Superwinch flatbed mounting plate so you think the bolts holes would suffice for lining up the winch, they weren't the winch ended up slightly askew and then the freespool was useless. I removed it twice before I found the problem with a level and measuring the freespool is now fine. The same bolt holes were used just carefully lined up before tightening. Quote Link to comment Share on other sites More sharing options...
