cant be this easy??
hi
is this really all i need to be able to megasquirt my rover v8? or do i need extra map sensors etc?
http://trigger-wheels.com/store/index1.html they sell the complete microsquirt system for rover v8s?
any reviews on this company?
what are the differences between microsquirt and megasquirt?
is that a good price??? (thats the big question i wanna know?)
any ideas or help plz
thanks
phill
Yes.
No.
Yes they do :P
I kinda object to the price they were charging for trigger wheels & sensor brackets, but since I got a batch of my own cut I don't have to buy them from them anymore so it doesn't bother me. I believe the guy who runs it is a member of the MS community & a nice chap, the stuff is nicely done and the price is not bad at all really.
Micro is more money, has an external MAP sensor and lower injector drive current (which from memory I think may be pushing it a little bit for a Rover V8 with 4 injectors per channel).
Yep.
If you want to get the most support from the guys above then you should look to getting MS1 rather than Micro.
If you then set it up with the same version of firmware/software they will know exactly what you have and how to help you.
A cheaper version of trigger wheel is available from Ford as fitted to transit vans.
Steve
cool info chaps,
can someone tell me where to get hold of the full megasquirt kit instead
of microsquirt then please if thats the better way to go for my v8?
thanks
phill
PM FridgeFreezer above. He should be able to supply all you need unless he's up to his ears in it.
Steve
tried to pm mr fridgefreezer and it says member cannot recieve any new messages????
all i wanna know is?
is it better to go for full megasquirt for my rover v8 due to low injector current of microsquirt?
which is better megasquirt 1 or 2??
how much a complete megasquirt kit is for my rover v8?
what parts are supplied?
how quickly can i get the parts?
and how much delivery to the isle of wight?
any help plz
phill
That'll be because my inbox was full (500 messages!) :o
And I'm not making any more ECU's for the moment, I don't have the free time.
Well I'd hope if trigger-wheels.com are selling them for Rover V8's they work OK, I know Bill & I have talked about it and concluded it could be close. My personal view is that Micro is 50 quid extra and less flexible (you can't add I/O as easily as it's all SMD) so "normal" MS would seem to make the most sense.
That depends on what you mean by better. For the average Land Rover V8, MS2 is overcomplicated. A normal MS1 on a V3 board is all you need.
Define complete - my usual kit is:
ECU
EDIS 8
Trigger wheel & sensor mount
30cm Wiring tail
Which runs to about £400, depending.
But you could also define it as:
ECU
EDIS 8
VR sensor
IAT sensor
lambda sensor & boss
Plug-and-play loom complete with all relays etc.
RS232 cable
Software CD
Big book of instructions
Vacuum hose & tee piece
2x coil packs & bracket
Which would be a few quid extra ;)
cool
any ideas where i can get hold of a ms1 on a v3 board kit from?
id be interested in the complete plug and play kit wiring loom price?
who sells the plug and play wiring kit?
ive been serching the internet for supplyers and most of them are in usa, id
rather buy from the good old uk! :D
thanks
phill
