TD5 power Posted December 7, 2009 Share Posted December 7, 2009 hi Im currently replacing the chassis on my 90 with a brand new one from Marslands, i have been trying to contact the DVLA about getting the VIN number transferred to the new chassis however my local office have advised me that i can not re use the original number and they have to inspect the vehicle and allocate a new one, does this sound right? how have others done it when replacing their chassis? I thought there was a thread about this but after much searching including google i can't find it so if anyone could locate it that would be much appreciated Many thanks Matt Quote Link to comment Share on other sites More sharing options...
adam300Tdi90 Posted December 7, 2009 Share Posted December 7, 2009 hi Im currently replacing the chassis on my 90 with a brand new one from Marslands, i have been trying to contact the DVLA about getting the VIN number transferred to the new chassis however my local office have advised me that i can not re use the original number and they have to inspect the vehicle and allocate a new one, does this sound right? how have others done it when replacing their chassis? I thought there was a thread about this but after much searching including google i can't find it so if anyone could locate it that would be much appreciated Many thanks Matt From DVLA..... Vehicles that have been rebuilt using a mix of new or used parts In order to retain the original registration mark: * cars and car-derived vans must use: The original unmodified chassis or unaltered bodyshell (i.e. body and chassis as one unit - monocoque); or a new chassis or monocoque bodyshell of the same specification as the original supported by evidence from the dealer or manufacturer (e.g. receipt). And two other major components from the original vehicle - ie suspension (front & back); steering assembly; axles (both); transmission or engine. DVLA Whoever told you that it had to be inspected was wrong... Unless, as it says above, you have had to replace more than just the chassis Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted December 7, 2009 Share Posted December 7, 2009 From Here : http://www.direct.gov.uk/en/Motoring/BuyingAndSellingAVehicle/RegisteringAVehicle/DG_10014246 In order to retain the original registration mark:cars and car-derived vans must use: The original unmodified chassis or unaltered bodyshell (i.e. body and chassis as one unit - monocoque); or a new chassis or monocoque bodyshell of the same specification as the original supported by evidence from the dealer or manufacturer (e.g. receipt). And two other major components from the original vehicle - ie suspension (front & back); steering assembly; axles (both); transmission or engine. If a second-hand chassis or monocoque bodyshell is used a car must pass an Individual Vehicle Approval (IVA) and light goods vans must have a enhanced single vehicle approval (ESVA) or single vehicle approval (SVA) test after which a "Q" prefix registration number will be allocated. Make sure you have the old chassis as they may wish to inspect that a well, and ensure numbers match the V5 Nige Quote Link to comment Share on other sites More sharing options...
T1G UP Posted December 7, 2009 Share Posted December 7, 2009 hi Im currently replacing the chassis on my 90 with a brand new one from Marslands, i have been trying to contact the DVLA about getting the VIN number transferred to the new chassis however my local office have advised me that i can not re use the original number and they have to inspect the vehicle and allocate a new one, does this sound right? how have others done it when replacing their chassis? I thought there was a thread about this but after much searching including google i can't find it so if anyone could locate it that would be much appreciated Many thanks Matt Stupid boy Pike! ask marshands to put the numbers on. keep it to yourself as you've now opened a BIG can of worms Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 7, 2009 Share Posted December 7, 2009 You still have to tell them about your re-chassis anyway Mr T1G, even if they don't need to inspect it (which they shouldn't assuming it meets the criteria set out above) they still need to know it's been done. Quote Link to comment Share on other sites More sharing options...
TD5 power Posted December 7, 2009 Author Share Posted December 7, 2009 hi thanks for the replies, the truck complies with the regulations above but i think they relate to the reg no rather than VIN. From what i understand i was advised they would have to issue me with a new vin because the chassis had been replaced i will try and get hold of them again tomorrow. I'm not sure how ive opened any cans of worms by replacing a like for like part. How would getting marslands to stamp the chassis no on be any different to me stamping it on, i never mentioned it whilst i was talking to marslands and they were good about answering any questions if it was such a major problem i would have thought it would have been mentioned. I ll let you know how i get on cheers matt Quote Link to comment Share on other sites More sharing options...
western Posted December 7, 2009 Share Posted December 7, 2009 AFAIK if the 'new' chassis is exactly the same as the 'old' the VIN is a straightforward transfer. Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted December 7, 2009 Share Posted December 7, 2009 Having just done exactly this... I followed the instructions to the letter and it was a very simple quick and easy process You need to send your logbook, photocopy of receipt for the new chassis, and a covering letter explaining you have carried out a direct swap with a new chassis In my case (and I believe they are doing this for more people now) I was invited to bring the vehicle to the local office for inspection, I turned up and a very nice man (who knew landys inside out) spent 5 mins checking the numbers matched (Richards put my old number on the new chassis) quick chat and 2 forms later I was done, total 10mins and I got an identical logbook sent to me in the post. NB this is NOT a VIC check like I thought at the time! All done with minimum fuss and all nice and legal There seems to have developed an attitude of 'SVA Police' and 'Anti-SVA-police' on the forum lately... My 2p worth, You're obliged by law to inform the dvla, whether you do or not is up to you, I'm certainly not going to interfere! Mike Quote Link to comment Share on other sites More sharing options...
TD5 power Posted December 7, 2009 Author Share Posted December 7, 2009 hi Thanks mike thats exactly what i was hoping for, was it your local office you had to send it to or DVLA swansea? I never though about getting the number stamped when i ordered the chassis, so there should be no problem with me stamping the number and then getting it inspected once its finished. thanks to everyone thats helped Matt Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted December 7, 2009 Share Posted December 7, 2009 Hi All of the above is dealt with by the local office, be warned though the time between sending the letter and getting the appointment back was about 6-8 weeks, once thats done the rest is dead quick! in fact, with hindsight its probably a better idea to take all your docs to the local office in person it might make it faster Mike Quote Link to comment Share on other sites More sharing options...
TD5 power Posted December 8, 2009 Author Share Posted December 8, 2009 ok cheers mike i ll get on with the rebuild, then get in contact with them again when i get close to being finished. How come it rains every time i get the spray gun out? don't we just love the british weather Matt Quote Link to comment Share on other sites More sharing options...
