Holyzeus Posted April 18, 2006 Share Posted April 18, 2006 I have a '84 four door therefore i presume the diffs are 10 spline? I can get a ARB (24 spline) cheap so i need a 24 spline diff what model LR's have these fitted and what production years? Also what else apart from half shafts would i have to change? Cheers Quote Link to comment Share on other sites More sharing options...
bishbosh Posted April 18, 2006 Share Posted April 18, 2006 I am sure a grown up will be along shortly who knows more, but I am pretty sure you will have to change the stub axle and numerous other things. The consensus when this has been asked before is that it is easier to get an axle from a later Disco and use that. Your 10 spline will be snapped up by someone wanting discs on the back of a 90. Sorry I can't be more specific. Quote Link to comment Share on other sites More sharing options...
isuzurover Posted April 18, 2006 Share Posted April 18, 2006 AFAIK bishbosh is correct, unless you can find some halfshafts from a rare 24 spline HD ninety rear. In the discos the switch to 24 spline was accompanied by a change to narrower stub axles, so you would have to change stub axles and hubs too. Quote Link to comment Share on other sites More sharing options...
Holyzeus Posted April 19, 2006 Author Share Posted April 19, 2006 Thanks for the info fella's, any idea just how late a Disco i need? Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted April 20, 2006 Share Posted April 20, 2006 Disco 1 from JA032850 should be 24 spline Quote Link to comment Share on other sites More sharing options...
Holyzeus Posted April 20, 2006 Author Share Posted April 20, 2006 Cheers, but sorry what does JA032850 mean?? Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted April 20, 2006 Share Posted April 20, 2006 Sorry, it's the last part of the VIN number on the plate under the bonnet. Quote Link to comment Share on other sites More sharing options...
Holyzeus Posted April 20, 2006 Author Share Posted April 20, 2006 Many thanks Quote Link to comment Share on other sites More sharing options...
Jay Posted June 9, 2006 Share Posted June 9, 2006 Many thanks Discos 1994 and above were 24 splines....i think rangies 92 and up were 24 splines. There should be easy to find but you will break them in no time they are only 20% stronger than the 10 spline. I have a full Maxidrive set up for sales (Maxidrive HD axles rear and front with complete third members set up in ARB RD 56 and Maxidrive R&P 4.75). Set up is located in Lebanon. Set up is on a disco with 36" tyres. Shipping sould not be that bad provided custom charges are not high in the UK. Thanks Jay Quote Link to comment Share on other sites More sharing options...
LR90 Posted June 9, 2006 Share Posted June 9, 2006 Can we just clarify a few things here. Firstly a 24spline (RD56) will fit a METRIC 10 spline diff, which is pretty much any diff post series so I don't see why a new diff is needed. You can fit it to the older imperial 10 spline diff too but need a pair of bearing sleeves. As to the rest of it are we talking front or rear? Jay, that's a nice setup you're offering. Is this just the internal or complete built up axles you are talking about. But why,, moving to bigger tyres/portals? Quote Link to comment Share on other sites More sharing options...
