dicsosfa Posted February 20, 2010 Share Posted February 20, 2010 hi been to wales at the weekend ( wish i never went now lol ) any way cut a long story short i reversed between our caravan and a tree i failed to notice a 6" branch , and as a result my rear corner on the passenger side ( light part only is now well creased. plus a slight bulge on the side panel at the joint easy repair) is now well creased. Q1.so can the corner piece only be replaced or is it all one piece Q2. how easy will it be , is it bolted.welded or glued or all of them Q3. how much will i pay for another panel second hand of coarse does anyone have instuctions or photo's on removing these panels thanks Roy Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 20, 2010 Share Posted February 20, 2010 All welded in I think, so not really a DIY prospect unless you want it to look like a dog's breakfast. Quote Link to comment Share on other sites More sharing options...
samd35 Posted February 21, 2010 Share Posted February 21, 2010 The D1 pannels are bolted and seam sealed so removing without damaging is dificult meaning that finding straight secondhand replacements wont be easy and they are two seperate pannels but I think that they are bolted together and then fitted to the vehicle as far as i could work out on the disco that i broke for parts a while ago and from memory you also have to strip out all the rear trip completley to get at the fixings! Hope this helps. Sam Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted February 21, 2010 Share Posted February 21, 2010 have you got i pic of what you've done Quote Link to comment Share on other sites More sharing options...
barmiebrumie Posted February 21, 2010 Share Posted February 21, 2010 As said rear quarters are bolted & glued as one piece, depending how bad it is, could be repaired, pics would be good but ali is not the easiest to repair, good luck with it though John Quote Link to comment Share on other sites More sharing options...
dicsosfa Posted February 21, 2010 Author Share Posted February 21, 2010 As said rear quarters are bolted & glued as one piece, depending how bad it is, could be repaired, pics would be good but ali is not the easiest to repair, good luck with it though John hi thanks for the replies will take some pics tomorrow and post them after work Roy Quote Link to comment Share on other sites More sharing options...
dicsosfa Posted February 27, 2010 Author Share Posted February 27, 2010 hi thanks for the replies will take some pics tomorrow and post them after work Roy hi here are some pic's if they work lol [/img] Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted February 27, 2010 Share Posted February 27, 2010 you could try putting a inner tub up in side and blowing it up, should push some of it out but were it's creased it wount get the crease out but should make it a bit better. i've done it before but it was on a side panel and worked a treat. Quote Link to comment Share on other sites More sharing options...
pw8757 Posted February 27, 2010 Share Posted February 27, 2010 This could be pulled out using a slam hammer (aka Slide Hammer - a metal tube with a weight running on it and a means of grabbing the fixing) - you drill a small hole and insert either a screw or a pop rivet, fix the end onto the slam hammer and slide the weight towards you - it will pull the metal out. You quickly get the hang of it. If you have Discovery, look at an episode of "Overhaulin" or "Wrecks to Riches USA" (Not to be confused with the British version...........) Also, you can get vacuum pullers for the "round" dents. Have a look at this selection from Machine Mart (My Fave!!) Get it as flat as you can and fill with thin layers of filler. Spray and polish Quote Link to comment Share on other sites More sharing options...
