Tibout Posted May 1, 2010 Share Posted May 1, 2010 hi there i'm still working on my landy taking so much of my time but i'm enjoying it a lot so far even though i'm only a novice but learning a lot from you guys!!! now i've discover i need to replace my right hand cv joint!!!! is there any thread with pics or could someone help me with this please!and also what part number should i get and is it better to get a kit!!! my landy is a defender 90 2.5td year 1988 a J reg i think not sure!!! thanks a lot thierry Quote Link to comment Share on other sites More sharing options...
white90 Posted May 1, 2010 Share Posted May 1, 2010 Tech Archive has all you need for this job Quote Link to comment Share on other sites More sharing options...
Tibout Posted May 1, 2010 Author Share Posted May 1, 2010 Tech Archive has all you need for this job thanks a lot for that Quote Link to comment Share on other sites More sharing options...
smokinv8 Posted August 28, 2010 Share Posted August 28, 2010 Have got to do this job myself but cant find any info in the tech archive. Has it been moved? Quote Link to comment Share on other sites More sharing options...
Tibout Posted August 28, 2010 Author Share Posted August 28, 2010 hi there i think i've put this post ages ago but i did'nt see and thread on the tech archive. but it's quiet straight forward the only bit which is tricky is to remove the old cv on the shaft i've secure the shaft in a soft grip and use a copper mallet to knock the cv off. don't forget to put a new circlip when putting the new cv. also i've cable tie the caliper first instead of rmoving the brake hose so avoiding the bleeding hassle. ask if you are stuck with something thierry Quote Link to comment Share on other sites More sharing options...
smokinv8 Posted August 29, 2010 Share Posted August 29, 2010 hi there i think i've put this post ages ago but i did'nt see and thread on the tech archive. but it's quiet straight forward the only bit which is tricky is to remove the old cv on the shaft i've secure the shaft in a soft grip and use a copper mallet to knock the cv off. don't forget to put a new circlip when putting the new cv. also i've cable tie the caliper first instead of rmoving the brake hose so avoiding the bleeding hassle. ask if you are stuck with something thierry I couldnt find it either but found some info on another forum. Doesnt look too bad a job to be honest. Thanks for the help. Neil Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 29, 2010 Share Posted August 29, 2010 I didnt change mine, but my thread shows quite a few pictures of the assembly of that area. I think the index of the TEch archive is/was down. Neil you have my number if you want to ask me anything about it Quote Link to comment Share on other sites More sharing options...
Hitower Posted August 30, 2010 Share Posted August 30, 2010 If you need any help, please tell. Ive recently done this job, it take me 4 mornings...to complete ,i've change the cv's and half shafts, and the bearings, seals...everything is new... In a few days i will do the other side, but first i need to solve the problems of my defender (ignition,diff seal bust....transfer box....)... go to this site...there is some information about the parts tha goes there... http://www.retroanaconda.com/landrover/parts_books/90/6_axles_suspension_engine_controls_p475-580.pdf hope this helps too.. http://www.fag.hiof.no/~frodehaa/axle.htm Quote Link to comment Share on other sites More sharing options...
smokinv8 Posted August 30, 2010 Share Posted August 30, 2010 Thanks for the help fellas, its a job Im tackling tomorrow. Gotta find out how many splines I got on my CV Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 30, 2010 Share Posted August 30, 2010 if i remember correctly, its a J reg, so will have 32 splines on the inner cage. Quote Link to comment Share on other sites More sharing options...
smokinv8 Posted August 31, 2010 Share Posted August 31, 2010 Good job I checked 1st Ross, it was 23 spline. Remind me not too trust you! Lol Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted August 31, 2010 Share Posted August 31, 2010 Not standard then, a truck of that age will have had 10-spline diffs and 32-spline CVs, ie. the worst possible setup. The 10-spline diff and 23-spline setup yours has is what came on earlier vehicles, much stronger at the CV end Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 31, 2010 Share Posted August 31, 2010 So I should have been right Same set-up as mine then Neil! Quote Link to comment Share on other sites More sharing options...
