Chris123 Posted May 11, 2010 Share Posted May 11, 2010 Morning all, I'm putting a disco 200tdi engine into my 90, and I'm currently swapping the bellhousing over from the 2.5TD. I'll be needing to renew the gasket between the bellhousing and the engine block. Is there a difference between the 2.5TD gasket, and the 200tdi gasket? If so which one should I order? Thanks, Chris Quote Link to comment Share on other sites More sharing options...
RaDi90Hybrid Posted May 11, 2010 Share Posted May 11, 2010 Morning all, I'm putting a disco 200tdi engine into my 90, and I'm currently swapping the bellhousing over from the 2.5TD. I'll be needing to renew the gasket between the bellhousing and the engine block. Is there a difference between the 2.5TD gasket, and the 200tdi gasket? If so which one should I order? Thanks, Chris Just wondering why you are changing the bell-housing? The Disco one should fit the gearbox OK but you will need to tap out a few of the holes at the bottom, I did when I did my 2.5NA. An intellegent person will correct me if I'm wrong I am sure. Andy Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 11, 2010 Share Posted May 11, 2010 N/A engine has an O-ring, and the TDi has a gasket - ERR1440. I would use the gasket or just some RTV sealant instead. Les. Quote Link to comment Share on other sites More sharing options...
Chris123 Posted May 11, 2010 Author Share Posted May 11, 2010 Ah, that's given me a bit of a choice now. I must admit I foolishly only found out about the bellhousing problem after trying to fit the engine. So I can either tap or replace the bellhousing. A couple of further questions if I may? 1) What size do I need to tap the new holes 2) Is there a guide to replacing the crank seal anywhere? I've tried searching the site, and unfortunately the old estonian manual archive is offline. (at least the downloads are anyway!) Thanks, Chris Quote Link to comment Share on other sites More sharing options...
markyboy Posted May 11, 2010 Share Posted May 11, 2010 Ah, that's given me a bit of a choice now. I must admit I foolishly only found out about the bellhousing problem after trying to fit the engine. So I can either tap or replace the bellhousing. A couple of further questions if I may? 1) What size do I need to tap the new holes - M10 2) Is there a guide to replacing the crank seal anywhere? I've tried searching the site, and unfortunately the old estonian manual archive is offline. (at least the downloads are anyway!) Don't know, have you searched the Tech Archive? Thanks, Chris Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 11, 2010 Share Posted May 11, 2010 Manuals are here: http://landroveroneten.com/index.php/general/land-rover-manuals/ Quote Link to comment Share on other sites More sharing options...
western Posted May 11, 2010 Share Posted May 11, 2010 Defender manual, says fill the seal groove with sealant [RTV] & fit with a new gasket. for the rear crank seal, fit the housing first then fit the seal, lightly lubricate the end of the crank & the seal lip, to help the seal slide on. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 11, 2010 Share Posted May 11, 2010 If you use the 2.5 flywheel housing, then you only need to remove one stud (by the slave cylinder), so no tapping involved and a lot easier. Tap would be M10 x 1.5 Les. Quote Link to comment Share on other sites More sharing options...
Chris123 Posted May 17, 2010 Author Share Posted May 17, 2010 Excellent, well I went for the tapping the disco bellhousing method, unfortunately despite tapping to the full depth the thread pulled out when torquing up. But I've decided to leave it as it is, as I'm running short on time to get this done. Now my further bad luck with bolts continues with trying to do the timing belt. 1 bolt sheered when removing the water pump, and 1 bolt sheered when remove the timing cover. Both in the top right hand corner (as looking at the engine from the front). I would be eternally grateful if someone could look up the part numbers for these bolts so I could order some new ones, or if someone has some of these spare and can post there's some beer tokens in it for you! Thanks, Chris Quote Link to comment Share on other sites More sharing options...
western Posted May 17, 2010 Share Posted May 17, 2010 Chris if you can add a picture of each bolts location so I can see their exact position, I can give you the part numbers for new bolts. Quote Link to comment Share on other sites More sharing options...
