removing a bush out of radius arms and drag links
I've just done 6 out of 8 of mine on the afore-mentioned hydraulic press, and had to use the hacksaw method for the last 2, although rather than the burning bit, I just pushed the centre out then cut through the rubber and outer shell with the hacksaw. Mine were of an '84 vintage (A very good year, so I'm told) and the rust around the outside can cause problems if the thing you're using to push them through isn't exactly the right size. Give them a good scrubbing with a wire brush first.
hth
Jake
