Jinx Reyneke Posted May 22, 2010 Share Posted May 22, 2010 I've checked earth between battery and chassis and engine and chassis all fine. Indicators work but no headlights or emergency flasher lights. Where do I look? Quote Link to comment Share on other sites More sharing options...
errol209 Posted May 22, 2010 Share Posted May 22, 2010 I've checked earth between battery and chassis and engine and chassis all fine. Indicators work but no headlights or emergency flasher lights. Where do I look? Hello in Mozambique! Can you tell us the model and year? It helps with which wiring diagram to choose ... Quote Link to comment Share on other sites More sharing options...
Wex Posted May 22, 2010 Share Posted May 22, 2010 Had the same problem a while back and it was a relay in the fusebox.Sorry I can't remember which one it was. '89 TD Quote Link to comment Share on other sites More sharing options...
Jinx Reyneke Posted May 23, 2010 Author Share Posted May 23, 2010 Hi, I have a 130 TDI 300 96 model From South Africa. I have changed the flasher relay behind the fuse panel at center bulkhead (in front of gear leaver)On the multi-plug of the hazard switch there is a much thinner black with red stripe wire just hanging out of the back of the plug. Where should it go to as it has a smaller type female shade connector? Quote Link to comment Share on other sites More sharing options...
western Posted May 23, 2010 Share Posted May 23, 2010 the thin wires at the hazard switch should be connected to the small terminals on each side of the switch to operate the internal warning light. Quote Link to comment Share on other sites More sharing options...
errol209 Posted May 23, 2010 Share Posted May 23, 2010 ^^ - as Ralph says for the hazard switch, but I think the headlights is a seperate problem. Quote Link to comment Share on other sites More sharing options...
western Posted May 23, 2010 Share Posted May 23, 2010 IIRC the headlight have seperate fuses for each side, wires behind each set of front lights, there's a earth connection there too. Quote Link to comment Share on other sites More sharing options...
zim Posted May 23, 2010 Share Posted May 23, 2010 Does the horn work and main beam flash, as on the RRC (which i'm assuming is the same as the def) there is a permanent 12v feed into the plug to do hazards, main beam flash and horn. G Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 23, 2010 Share Posted May 23, 2010 9 out of 10 problems with both headlights out are caused by a duff headlight switch. Mo Quote Link to comment Share on other sites More sharing options...
Jinx Reyneke Posted May 23, 2010 Author Share Posted May 23, 2010 ok have changed out the headlight switch and now have all the lights back but not indicators or hazard's I am just pulling that switch apart to see if there is a bad contact Quote Link to comment Share on other sites More sharing options...
western Posted May 23, 2010 Share Posted May 23, 2010 this link should help http://forums.lr4x4.com/index.php?showtopic=25376 Quote Link to comment Share on other sites More sharing options...
Jinx Reyneke Posted May 23, 2010 Author Share Posted May 23, 2010 yip horn works as well as high and lo beams as well high flash. still no indicators or hazard's. on the side of the hazard switch I have one wire only and that is connected. But out of the back of the plug there is one thinner wire black with red stripe. where does that go to? it looks as though it should be to the back of the clocks? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 23, 2010 Share Posted May 23, 2010 Try substituting the hazard flasher switch for another. Mo Quote Link to comment Share on other sites More sharing options...
errol209 Posted May 23, 2010 Share Posted May 23, 2010 yip horn works as well as high and lo beams as well high flash. still no indicators or hazard's. on the side of the hazard switch I have one wire only and that is connected. But out of the back of the plug there is one thinner wire black with red stripe. where does that go to? it looks as though it should be to the back of the clocks? It should go from the hazard light switch to the hazard warning light: Quote Link to comment Share on other sites More sharing options...
western Posted May 23, 2010 Share Posted May 23, 2010 yip horn works as well as high and lo beams as well high flash. still no indicators or hazard's. on the side of the hazard switch I have one wire only and that is connected. But out of the back of the plug there is one thinner wire black with red stripe. where does that go to? it looks as though it should be to the back of the clocks? see my reply further up & the link to the hazard switch info from our tech archive. Quote Link to comment Share on other sites More sharing options...
Jinx Reyneke Posted May 23, 2010 Author Share Posted May 23, 2010 Thanks so much for everyone's help but it looks like the hazard switch is shot and I think I might have to get new light and indicator stalk units as well. Thanks Quote Link to comment Share on other sites More sharing options...
