Mean Green Posted July 6, 2010 Share Posted July 6, 2010 Really as the title says, what should I do to prepare my garage floor for painting. It was done when the garage was built about 5 years agoand lasted ok for about 2 years, but now it is a bit shabby so I would like to spruce it up a bit. The only problem are the oil (and other) stains - will they effect the paint? I have a tin of International Garage floor paint that I intend to use. Should I give it a wash down with something first? I dont want to use th epressure washer as I do not intend emptying all my carp stock out, I will just clear the floor and paint round the shelf units etc. any advice? Quote Link to comment Share on other sites More sharing options...
milliejasper1111 Posted July 6, 2010 Share Posted July 6, 2010 P.V.A It first!! Ian Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted July 6, 2010 Share Posted July 6, 2010 P.V.A It first!! Ian Good advice........... the only other advice that i could give would be to thin down the first coat of paint, and let that dry then apply another coat neat................... and then let it dry fully before you park ANYTHING on it.......... otherwsise the paint will stick to the tyres and come off when you roll it out....... Quote Link to comment Share on other sites More sharing options...
Mean Green Posted July 6, 2010 Author Share Posted July 6, 2010 P.V.A It first!! Ian Just neat PVA or should it be watered down? Would this be instead of thinned down coat? or should it be PVA then thin coat then full coat? Quote Link to comment Share on other sites More sharing options...
sotal Posted July 6, 2010 Share Posted July 6, 2010 We did a warehouse floor recently - the paint we used (can't remember make) said to apply direct to concrete, we just had to sweep it all first, then apply the 1st coat thinned down 50/50, then leave it over night, then paint it neat. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 6, 2010 Share Posted July 6, 2010 IIRC when I did mine I used an International Paints sealer / primer having first "dusted" (vacuumed, but don't tell SWMBO!!) the floor and degreased suspect areas. Quote Link to comment Share on other sites More sharing options...
milliejasper1111 Posted July 7, 2010 Share Posted July 7, 2010 Just neat PVA or should it be watered down? Would this be instead of thinned down coat? or should it be PVA then thin coat then full coat? water it down so its nice and thin, give the floor a good clean, get all the dust off. One good coat of that and let dry for a few hours, the floor will be sealed good and propper. The paint should then stick like brown stuff to a blanket! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 7, 2010 Share Posted July 7, 2010 Read the tin of paint too, some say the concrete has to be down for 2 years! Quote Link to comment Share on other sites More sharing options...
reads90 Posted July 7, 2010 Share Posted July 7, 2010 When i did mine i was told to diloted some of the acid you put in your pool and clean the floor with that. It gets rid of all the oil and carp of the floor. Then wash with clean water and let dry and your ready to paint. Pretty easy i have a load of pool acid and you can buy it everywhere and it cheap Quote Link to comment Share on other sites More sharing options...
