New porblem,....winch
The reason the brake is there is to hold you, or stop the cable from simply pulling off the drum....
Lets assume you were winching yourself uphill, and you stop the winch motor, if there was no brake, the weight on the cable could easily pull the cable off the drum, and you would go back down the hill, not a good plan, however, as said, if the winch stays the wrong way around, you will be pulling against the brake all the time, and it won;t last very long at-all!!
I have a 12000lb winch similar to hitower, took it apart for a fettle the brake in the drum core works on a simple inertia type linkage, yeah, I think it wise to get it turned the right way round. From memory there is a bias for the brake working.
Some pictures all be it not so clear here...
Linky
