Defender_300Tdi Posted October 2, 2010 Share Posted October 2, 2010 Right my B posts on my 110 are shot and by shot I mean totally! I have been offered a set of Series 3 county station wagon B-posts, it maybe a daft question but will the Series 3 B-posts fit a 110? I mean I know you can fit a Defender front door on Series 3, so would a second row door fit? The only things that I can think of that would be different would be the door catch as mine is fitted with push button doors and now lift up handle Series 3 doors. Are the Series 3 B-posts held on/attached differently? I mean I wouldn’t be resorting to this, but 110 B-posts seem to be like rocking horse poo and even if a breaker does have them they seem to want daft money for them. Any help much appreciated. Regards Rob Quote Link to comment Share on other sites More sharing options...
western Posted October 2, 2010 Share Posted October 2, 2010 which part of the body side frame B post is rotten, recently repaired my 110's sill section with 50 x 30 x3mm rectangular box & some slightly bigger box for the angled part inside the rear doors, S3 bit would probably fit, there are most likely slight differnces between S3 & 110 side frames, part numbers are different for S3 & 110. Quote Link to comment Share on other sites More sharing options...
Defender_300Tdi Posted October 2, 2010 Author Share Posted October 2, 2010 Pretty much all the sill has gone as has most of the bottom of the actual post. So You dont think they will fit then Ralph? I was really hoping that they would! Nuts. Rob Quote Link to comment Share on other sites More sharing options...
western Posted October 2, 2010 Share Posted October 2, 2010 only way to know for sure is to have both side by side, Series 3 parts book, see page 2G 17 for the side frame/B post assembly From Craddocks website USE MUC 9126 (#MUC2588) muc2588 is the S3 part. Quote Link to comment Share on other sites More sharing options...
Defender_300Tdi Posted October 2, 2010 Author Share Posted October 2, 2010 Someone must have thought of this before?! Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 2, 2010 Share Posted October 2, 2010 Last breaker I spoke to wanted £250 a side. Bonkers money, but not quite as bonkers as Land Rover's price. Personally, I'm praying mine are savable with some box section, then they'll be going for galvanising along with everything else made of steel. Here is a Series III body-side frame: And here is a 110 one: They look similar, the basic construction appears the same, although the Series III one appears to have some extra plate at the back end. Only way to know for sure though is as above, to see them side-by-side. Quote Link to comment Share on other sites More sharing options...
western Posted October 2, 2010 Share Posted October 2, 2010 S3 doors will fit a 110, so the actual side frame diemensions must be the same, the extra 1 inch between 109 & 110 will be within the axle mounting/suspension, not in the body diemensions. Quote Link to comment Share on other sites More sharing options...
western Posted October 2, 2010 Share Posted October 2, 2010 Last breaker I spoke to wanted £250 a side. Bonkers money, but not quite as bonkers as Land Rover's price. Personally, I'm praying mine are savable with some box section, then they'll be going for galvanising along with everything else made of steel. Here is a Series III body-side frame: And here is a 110 one: They look similar, the basic construction appears the same, although the Series III one appears to have some extra plate at the back end. Only way to know for sure though is as above, to see them side-by-side. the triangular body panel just to the right of the letter E is common to 110 SW too, Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 2, 2010 Share Posted October 2, 2010 I tried to find a pair of these for my 109, the part is superseded to the 110 bit so I presume there's no great difference. Since I couldn't find new ones (no-one had any, no-one knew when you'd get any more) and even ratty sets were going for £250 on eBay, I re-made mine using box section. They were gone the same as yours - sill & bottom of pillar. Better off putting the money towards a welder if they're anyway like as expensive as when I did it. Quote Link to comment Share on other sites More sharing options...
