Macker Posted October 6, 2010 Share Posted October 6, 2010 Hello, had a leaky clutch master cylinder on my series 3. Was leaking from the plunger and where the clutch pipe screws into the master. So I bought a new master cylinder, no more leaks from the plunger. I fitted a new copper washer and it still leaks from this fitting. The block that connects the pipe to the master was a bit rusty on the surface but I figured it'd be OK, could this be why it's still leaking? Any tips on how to get it to stop? This is the piece in question, I was hesitant to order a new on as it's expensive! http://www.roversnorth.com/store/p-1014-adapter-clutch-master-cylinder.aspx leaked clutch fluid on my freshly painted footwell! Thanks Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 6, 2010 Share Posted October 6, 2010 You could try thread locking fluid, such as torqueseal or similar. PTFE plumbers tape is commonly used as well. Les. Quote Link to comment Share on other sites More sharing options...
luke keeper of badger Posted October 6, 2010 Share Posted October 6, 2010 hi i use this ebay item http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=380104935161&ru=http://shop.ebay.co.uk:80/%3F_from%3DR40%26_trksid%3Dp3984.m570.l1313%26_nkw%3D380104935161%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1#ht_500wt_928 luke Quote Link to comment Share on other sites More sharing options...
rtbarton Posted October 6, 2010 Share Posted October 6, 2010 Try annealing the copper washer, heat it to red heat and drop it into some cold water. Make sure all mating surfaces are clean. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 6, 2010 Share Posted October 6, 2010 http://www.cbsonline.co.uk/brass-union-38-unf-male-to-716-unf-female-bu38716-4881-p.asp Bit cheaper than the randomly-expensive Land Rover part Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 8, 2010 Share Posted October 8, 2010 Try annealing the copper washer, heat it to red heat and drop it into some cold water. Make sure all mating surfaces are clean. That is quenching, not annealing, and hardens the metal. Annealing will soften the copper, and needs to be allowed to cool gradually, not quickly. It's a good way of re-using an old sealing washer, though, if you don't have a new one to hand, though new would be better. Quote Link to comment Share on other sites More sharing options...
rtbarton Posted October 8, 2010 Share Posted October 8, 2010 That is quenching, not annealing, and hardens the metal. Annealing will soften the copper, and needs to be allowed to cool gradually, not quickly. It's a good way of re-using an old sealing washer, though, if you don't have a new one to hand, though new would be better. Not with copper it doesn't, you can let it cool slowly or quench it, it will still soften, ie anneal. The advantage of quenching in water is that the scale will be removed. Quote Link to comment Share on other sites More sharing options...
