Souster Posted October 8, 2010 Share Posted October 8, 2010 Hi folks, m looking into fitting an oil pressure gauge to my mud console. How do i go about doing it as regards to wireing it up as well as the oil pressure light. It will be electric gauge also, not mechanical... Something like a durite gauge maybe. Ive done a search nothing has really come up for a 300tdi, and to be honest i have no idea. Any help would be greatly appreciated. Can anyone recommed a gauge that should be in a land rover (I know its personal preference but still)... So far im using a volt meter and oil pressure gauge any one got an ideas. (land rover is pretty standard) Many thanks in advance, Josh Quote Link to comment Share on other sites More sharing options...
LiamC Posted October 8, 2010 Share Posted October 8, 2010 I fitted one to my 200tdi. I purchased an aftermarket gauge with sender. Most after market gauges seem to have a 1/8NPT thread on the sender, the thread on the LR pressure switch is 10mmx1mm. So I purchased a T-piece with 10x1 male - 10x1 female with a 1/8NPT female on the side, then simply fitted it all together. This enabled me to fit the gauge and still have the benefit of the warning light too. Quote Link to comment Share on other sites More sharing options...
Souster Posted October 8, 2010 Author Share Posted October 8, 2010 Cheers liam for the reply, thats fantanstic exactly what i wanted to know. Quote Link to comment Share on other sites More sharing options...
Souster Posted October 8, 2010 Author Share Posted October 8, 2010 Does anyone know where i can find the sender connected to the engine, is it by the oil filter by any chance? Quote Link to comment Share on other sites More sharing options...
western Posted October 8, 2010 Share Posted October 8, 2010 on the oil filter head next to the pipe that goes to oil cooler in radiator. Quote Link to comment Share on other sites More sharing options...
Souster Posted October 8, 2010 Author Share Posted October 8, 2010 Cheers western, so all need to do is remove that.. Fit the T peice and then screw the old sender and new sender for the gauge into the T peice. Sounds good to me! Thanks alot:) Quote Link to comment Share on other sites More sharing options...
western Posted October 8, 2010 Share Posted October 8, 2010 Yep, same as I did on my 200Tdi, use new copper washers too. Quote Link to comment Share on other sites More sharing options...
Alastair Dixon Posted July 16, 2011 Share Posted July 16, 2011 I'm thinking of fitting a mechanical durite oil pressure gauge to my 200tdi and I was just going to remove the oil pressure switch and fit the feed to the gauge in its place. Would this work, or is there any other blanking plugs I could use instead? Also, the gauge came with all the adaptors and there seems to be one that is willing to thread in but I think I would like to keep the pressure switch too? Where would I get a T piece from? Quote Link to comment Share on other sites More sharing options...
western Posted July 16, 2011 Share Posted July 16, 2011 [name=Alastair Dixon' timestamp='1310849725' post='595696] I'm thinking of fitting a mechanical durite oil pressure gauge to my 200tdi and I was just going to remove the oil pressure switch and fit the feed to the gauge in its place. Would this work, or is there any other blanking plugs I could use instead?Also, the gauge came with all the adaptors and there seems to be one that is willing to thread in but I think I would like to keep the pressure switch too? Where would I get a T piece from? I used these 2.5 petrol & n/a & TD diesel parts on my Defender spec 200tdi, oil filter head is common to all the pre-300Tdi 2.5 litre engines photo's of my set up & modified parts page with hand drawn parts & numbers attached. oil pressure gauge trnamitter fittings.pdf Quote Link to comment Share on other sites More sharing options...
Dads Toy Posted July 17, 2011 Share Posted July 17, 2011 See the recent thread "300TDi oil pressure sender for factory gauge" further down the page. Malcolm Quote Link to comment Share on other sites More sharing options...
