robhybrid Posted October 11, 2010 Share Posted October 11, 2010 does anyone on hear now the gear ratio of the drop box on simca axles? Quote Link to comment Share on other sites More sharing options...
gsr341 Posted October 11, 2010 Share Posted October 11, 2010 you ever felt the weight of simca axels rob Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 11, 2010 Share Posted October 11, 2010 Try PMing Ripley - he built a truck with a pair of simcas on HERE Quote Link to comment Share on other sites More sharing options...
robhybrid Posted October 11, 2010 Author Share Posted October 11, 2010 you ever felt the weight of simca axels rob No but I have heard loads of people complaining about them. I was contemplating possibly making my own hybrid axles using just the drop box. Was thinking portals on a budget. Interested in knowing the drop box gear ratio before going any further than vapor build. another idea for vapor build was 4wd tractor front axles with huge tyres? Just thought portal might allow me to keep my old tyres. Quote Link to comment Share on other sites More sharing options...
gibbon Posted October 11, 2010 Share Posted October 11, 2010 Give Brian at Tonks 4x4 in mansfield/notts area a call, he's built with them before and thats where ripley's axles came from Quote Link to comment Share on other sites More sharing options...
plasticbadger Posted October 12, 2010 Share Posted October 12, 2010 The other problem with the Simca set up is that the drop box is inboard of the swivel giving a huge scrub radius and comprimising the gained ground clearance. I don't know if that could be over come in a custom build, but something like Mog 404 boxes or Hummer boxes may be a better option. Mog 404 boxes have a 2.13:1 ratio Hummer boxes have a 1.92:1 ratio They both still have the problem of only 2 gears, so the axles need to run 'backwards'. The Hummer is smaller and lighter, has more sensible stub pattern, but issues of where to fit brakes. The Mog is bigger and stronger, but has a Mog specific stud pattern and heavy drum brakes. There's also Volvo and Pinzgauer boxes, but the above are the only ones I've played with in the flesh. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 12, 2010 Share Posted October 12, 2010 Think Volvos are around the 2.09:1 ratio in the drop box. Quote Link to comment Share on other sites More sharing options...
