Tibout Posted October 20, 2010 Share Posted October 20, 2010 hi does anyone know any alternative seats i can fit in a defender 90 without any major modification. something comfortable and cheap and easy enough to source in a scrap yard for e.g thanks a mil thierry Quote Link to comment Share on other sites More sharing options...
adam300Tdi90 Posted October 21, 2010 Share Posted October 21, 2010 Range rover classic seats, have the same width mountings as standard 90 seats, but shorter depth. I replaced the seat box covers with thicker steel. Used the front mounts to bolt through the seat runners, then the new steel plate, then into the seat box. The rear of the front seats mount through the new steel plate, and the rear of the steel plate bolts to the standard seat mounts. Easy.. But annoying you can't get to the batteries easily. I have used an 'Anderson' plug from one of the batteries just in case I ever have to jump it or somebody else... then you can buy (or make) some special 'anderson to battery clip' leads for jump leads... Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted October 21, 2010 Share Posted October 21, 2010 Someone told me Citreon AX seats as they have removable squab seats....Dunno if its true though!! Quote Link to comment Share on other sites More sharing options...
tomaco1 Posted October 21, 2010 Share Posted October 21, 2010 I used corbeau gts II with a set of rails made by a guy in the states, kind of a quick release system. I can get some pics if needed Quote Link to comment Share on other sites More sharing options...
Tibout Posted October 21, 2010 Author Share Posted October 21, 2010 thanks lads pictures will be great i'm just wondering if i'll re trim y actual one's or try to get something more comfy may be Quote Link to comment Share on other sites More sharing options...
draper40 Posted October 21, 2010 Share Posted October 21, 2010 I picked up the whole interior of a classic range rover for £80. Fitted the back bench seat in my 90 then sold the RRC front seats for £100, so they cost me -£20!! Very comfy and they tip so you can still access the battery! Pete Quote Link to comment Share on other sites More sharing options...
maxenrover Posted September 6, 2019 Share Posted September 6, 2019 On 10/21/2010 at 11:41 PM, draper40 said: I picked up the whole interior of a classic range rover for £80. Fitted the back bench seat in my 90 then sold the RRC front seats for £100, so they cost me -£20!! Very comfy and they tip so you can still access the battery! Pete Hello that just looks awesome, if your still on This forum i Would like to ask if you have any more pics so i Can see How you have Done it or if you Can tell me? Im very intrested, but wow 9years ago.... , but still very cool! -:Max Quote Link to comment Share on other sites More sharing options...
Pappa Smurf Posted September 7, 2019 Share Posted September 7, 2019 I find retrimmed standard seats are perfectly comfortable. Easy to do at home. Quote Link to comment Share on other sites More sharing options...
