steve-c Posted October 21, 2010 Share Posted October 21, 2010 Hi guys and gals How can you tell if your swivels have one shot grease in them or you have ran out of oil ? and if they do have grease in them does it ever need topping up or changing ? Cheers Steve Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 21, 2010 Share Posted October 21, 2010 The grease is in theory there for the life of the truck. Have your swivels got a drain hole in them or not? they only take something like 0.33L in each side of oil, so if there is a drain hole I'd pull it and see what comes out. HTH Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 22, 2010 Share Posted October 22, 2010 Undo the filler/level plug and stick your finger/straw/sliver of wood, in there and see what is on it. Les. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 22, 2010 Share Posted October 22, 2010 Steve, the swivel grease is quite runny and some should come out if you remove the drain plug. Mo Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 22, 2010 Share Posted October 22, 2010 Depends on the age Mo... later axles, designed for grease, don't have the drain holes. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 22, 2010 Share Posted October 22, 2010 Indeed Ross, but the age of the axle isn't mentioned. Mo Quote Link to comment Share on other sites More sharing options...
steve-c Posted October 23, 2010 Author Share Posted October 23, 2010 Cheers guys it's on a 91 plate. will check to see whats comes out the drain holes.. cheers steve Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 23, 2010 Share Posted October 23, 2010 If original then it should be oil in there at that age. Although a lot of people put grease in when they start leaking the oil out (grease stays in better). I'm an oil man myself Quote Link to comment Share on other sites More sharing options...
