billysmart Posted November 19, 2010 Share Posted November 19, 2010 Hi Folk, i have had a problem with the passenger door for some time where i pull the handle the door will just not open, now i am having the same problem with the drivers door. Is there any adjustments that can be made to the mech so that it releases the catch to open the door without pulling the handle off? , the rear doors are fine as they dont get used as much. Many Thanks in advance Paul Quote Link to comment Share on other sites More sharing options...
Tetsu0san Posted November 19, 2010 Share Posted November 19, 2010 It is probably the spring in the latch which keeps the lock button up. It's a common problem and usually requires a new spring in the lock. If the handle pulls OK and is not stiff but it just won't open, then that is probably the reason. Could be wrong though. Quote Link to comment Share on other sites More sharing options...
billysmart Posted November 19, 2010 Author Share Posted November 19, 2010 If the handle pulls OK and is not stiff but it just won't open, then that is probably the reason. Could be wrong though. The handle is fine, no catching or stiffness, is the spring a LR part or will just a replacement spring do the job, any ideas where to get one....two... Many Thanks Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 20, 2010 Share Posted November 20, 2010 On Ebay I think Quote Link to comment Share on other sites More sharing options...
billysmart Posted November 20, 2010 Author Share Posted November 20, 2010 Many Thanks Quote Link to comment Share on other sites More sharing options...
James NZ Posted November 20, 2010 Share Posted November 20, 2010 Hi I saw them on Ebay recently as well, try this - http://cgi.ebay.com/Land-Rover-Discovery-Door-Lock-Repair-Spring-5-door-set-/200545578093?pt=AU_Car_Parts_Accessories&hash=item2eb172ac6d Cheers, James NZ Quote Link to comment Share on other sites More sharing options...
fozsug Posted November 20, 2010 Share Posted November 20, 2010 Part number MTC9505 87 pence genuine CLICKY HTH Tony Quote Link to comment Share on other sites More sharing options...
bear Posted November 20, 2010 Share Posted November 20, 2010 Hi, Had a similar problem on my old 200tdi. When I took the door trim off I could see a nylon plunger that operated the locking mechanism was bending instead of staying straight. Gave the whole lot a good spray with WD40 which helped for a while but didn't cure it permenently. Someone may have a fix without buying new lock. Regards. Quote Link to comment Share on other sites More sharing options...
jamesvfr Posted November 20, 2010 Share Posted November 20, 2010 I had this on my 200 shape drivers door, if i pulled extremely hard (almost pulling it off) it would sometimes open, took door off + just had to adjust the handle, all back together + 100% again James Quote Link to comment Share on other sites More sharing options...
