Les Henson Posted June 16, 2006 Share Posted June 16, 2006 If your old clutch fork did this:- Then do this to the new one and it'll last ages longer. The end. Les. Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted June 16, 2006 Share Posted June 16, 2006 Good idea..... Just needs less weld and painting orange Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted June 16, 2006 Share Posted June 16, 2006 Call it the "S.I.R Yawforked" Nige Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 16, 2006 Share Posted June 16, 2006 They also sometimes split across the middle of the dome. I am told that a repair bodge here years ago was to take the cup out of a drop arm ball joint kit and weld it over the back of the domed bit. By the time the ball wears through that, the rest is probably about f***ed Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted June 16, 2006 Share Posted June 16, 2006 Les, what did you weld over it? just "weld" or a washer? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 16, 2006 Author Share Posted June 16, 2006 Jim I heated a square of 3mm plate until it was cherry red, then hammered it to the exact shape of the dome and then welded it in place. Easy to do with oxy gear. Les. Quote Link to comment Share on other sites More sharing options...
JST Posted June 17, 2006 Share Posted June 17, 2006 Steve, don't you get too much play in the ball joint if you do that.................... Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 17, 2006 Author Share Posted June 17, 2006 That's what cable ties are for. Les. Quote Link to comment Share on other sites More sharing options...
freeagent Posted June 17, 2006 Share Posted June 17, 2006 Good idea.....Just needs less weld and painting orange i'm glad he didn't paint it orange... because he would have charged me twice the money, been realy rude... and it would have failed before i got it home.... Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 17, 2006 Author Share Posted June 17, 2006 You mean it's still ok? Now that's a record for me! Les. Quote Link to comment Share on other sites More sharing options...
