brighouse shed Posted November 27, 2010 Share Posted November 27, 2010 I have some spider type wind on snow chains which amazingly will fit my landrover other cars run autosox, question which wheels should i fit them to? Quote Link to comment Share on other sites More sharing options...
Bluemoon Posted November 27, 2010 Share Posted November 27, 2010 front wheels, gives you traction and steering, Brian Quote Link to comment Share on other sites More sharing options...
smokinv8 Posted November 27, 2010 Share Posted November 27, 2010 Definately front. Mate of mine came along with us on a very snowy day and outdid us all using snow chains on the front and just AT tyres whereas we all had Special traks and laughed at him at 1st! Quote Link to comment Share on other sites More sharing options...
brighouse shed Posted November 27, 2010 Author Share Posted November 27, 2010 thanks reckon it's fronts then, just wondered if there was a rear bias in the drive say 55 45 just to reduce tyre wear on the fronts, but that said running ATs anyway so gonna take some time to wear that much Tony Quote Link to comment Share on other sites More sharing options...
PGM316 Posted November 28, 2010 Share Posted November 28, 2010 And having them on the front helps you stop faster! I like it on Ice Road Truckers were they call not having snow chains on "going barefoot" Quote Link to comment Share on other sites More sharing options...
tacr2man Posted November 28, 2010 Share Posted November 28, 2010 Dont try and use the spider type chains in anger as they will not handle the sort of torqueloads a landrover will put on them , but as a get you out of trouble aid they are easy to use . l Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted December 3, 2010 Share Posted December 3, 2010 A similar thread is here: http://forums.lr4x4.com/index.php?showtopic=62757 Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted December 4, 2010 Share Posted December 4, 2010 According the the manual on a defender they should be fitted rear as Mike has linked. Quote Link to comment Share on other sites More sharing options...
tacr2man Posted December 4, 2010 Share Posted December 4, 2010 The manual may say that but experience says other , as also stated on the other thread . Quote Link to comment Share on other sites More sharing options...
Diff Posted December 4, 2010 Share Posted December 4, 2010 According the the manual on a defender they should be fitted rear as Mike has linked. I think you have misread the instructions in the manual - It isn't very well worded but if you read it carefully, it means: If only one set of LR approved chains is available, they should be fitted to the front. The manual says NON APPROVED chains should be fitted to the rear. This is ONLY because non approved types MIGHT catch on the brakes. This is the genuine part wording from Land Rover's Accessory brochure: Snow Chains - 235/65 and 265/75 R16 tyres Part No: STC8518 Snow Chains give improved steering and braking control on snow and ice, when fitted to front wheels (can also be fitted to rear wheels when necessary). Easy-fit design, manufactured from high quality hardened galvanised steel, the chains are supplied in a tough vinyl carry bag for storage when not in use. Hope this helps, Regards, Diff. Quote Link to comment Share on other sites More sharing options...
