Paul H Posted December 7, 2010 Share Posted December 7, 2010 So today as i drove out of work i put the blower lever to position 2 to clear the screen. After a couple of seconds i noticed a load of smoke from behind the dash and the blower stopped working. The question is would this be the motor siezed up and the smoke travelling behind the dash and coming out around the instrument area or will it have fried the wires from the lever? Just trying to work out what parts i might need to fix it at the weekend. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 7, 2010 Share Posted December 7, 2010 I expect you need to investigate to find out. Did the smoke come out the vent ? If it was the motor you'd think, for it to come into the cab, it'd have to pass through the pipework, otherwise wouldn't it be under the bonnet? Could you smell burnt wiring? Quote Link to comment Share on other sites More sharing options...
western Posted December 7, 2010 Share Posted December 7, 2010 remove the instrument pack & check the blower slider switch & wiring as far as possible, ensure battery is disconnected or blower motor fuse is removed then remove the wing top grille & see if you can turn the blower fan by haand. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 7, 2010 Share Posted December 7, 2010 Sounds like the fan control switch to me By no means unusual alas, I've had the same thing happen on my old 90. HTH Mo Quote Link to comment Share on other sites More sharing options...
Paul H Posted December 8, 2010 Author Share Posted December 8, 2010 Thanks for the replies. It looks like it might be more serious. Tried it today and it atarted and ran fine and the blower appeared to work. Went for a drive and after about two miles suddenly loads of smoke and the engine cuts out. Wipers stopped mid sweep and nothing working. Flicked the isolation switch to disconnect the battery and turned off the ignition. When i turned on the battery again the engine turns over without the key being in but wont fire. I am starting to think that it may be linked to the sigma alarm/imobiliser that the previous owner had fitted. Will have to investigate further at the weekend. Quote Link to comment Share on other sites More sharing options...
