JST Posted June 22, 2006 Share Posted June 22, 2006 Oops, i did my 300 crank oil seal from the timing belt side. oh well. Quote Link to comment Share on other sites More sharing options...
western Posted June 22, 2006 Share Posted June 22, 2006 Oops, i did my 300 crank oil seal from the timing belt side. oh well. That'll be the dust seal in the front cover then,which is fitted from the inside [timing belt side]of the front cover,the crank front oil seal can only be fitted as I described above. Quote Link to comment Share on other sites More sharing options...
JST Posted June 22, 2006 Share Posted June 22, 2006 is that a different front cover to the one you remove when you change the timing belt? i changed the one in the cover removed to change the belt, the one on behind the sproket on the crank held on by woodruff key and the cam oil seal. looks like i may have done it wrong then - oh well, it didnt leak and its sold now. Quote Link to comment Share on other sites More sharing options...
western Posted June 22, 2006 Share Posted June 22, 2006 is that a different front cover to the one you remove when you change the timing belt?i changed the one in the cover removed to change the belt, the one on behind the sproket on the crank held on by woodruff key and the cam oil seal. looks like i may have done it wrong then - oh well, it didnt leak and its sold now. Think your getting a bit confused by names, the Front cover is the one that is removed to do a timing belt change, the timing case is the rear section the belt/pulley's live in & it's bolted to the front face of the engine block, if you've changed 3 seals then it's OK, 300Tdi engine workshop manuals shows the cam & crank oil seals fitted from the rear face of the timing case, so that must be removed to change them, same on a 200Tdi Quote Link to comment Share on other sites More sharing options...
white90 Posted June 22, 2006 Author Share Posted June 22, 2006 the crank/cam seal are fitted into the timing chest (where the pulleys live, they are fitted as James says once the timing cover is removed then the crank pulley after the woodruff key has been removed. you don't remove th timing chest to fit those seals, just the relevant pulleys. or do you mean "workshop manuals shows the cam & crank oil seals fitted IN the rear face of the timing case, so that the pulleys must be removed to change them, same on a 200Tdi ? Quote Link to comment Share on other sites More sharing options...
white90 Posted June 22, 2006 Author Share Posted June 22, 2006 Like here Quote Link to comment Share on other sites More sharing options...
western Posted June 22, 2006 Share Posted June 22, 2006 (edited) Hmmm, Methinks I got it wrong then for the crank & cam oil seals, just checked my 200Tdi book & it shows they both fit from the timing belt side as per the extract above ^^^^ I should have first before replying, for some reason I thought I did them from the engine block side [timing case removed] the front cover dust seal fits from the timing belt side. on another note --- Tony -- how did you capture that RAVE page, I can't get my notebook to do it, is there a set key sequence ?? Edited June 22, 2006 by western Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted June 22, 2006 Share Posted June 22, 2006 on another note --- Tony -- how did you capture that RAVE page, I can't get my notebook to do it, is there a set key sequence ?? Ralph, You can PRT Screen and save it as bmp (it copys the screen to the clip board)............... or use PSP (Paint Shop Pro) and screen capture / edit from that. If you need PSP, drop me a PM an I'll sort it out when I get back from Hols. Ian Quote Link to comment Share on other sites More sharing options...
western Posted June 23, 2006 Share Posted June 23, 2006 Ralph,You can PRT Screen and save it as bmp (it copys the screen to the clip board)............... or use PSP (Paint Shop Pro) and screen capture / edit from that. If you need PSP, drop me a PM an I'll sort it out when I get back from Hols. Ian Cheers Ian, I'll give that a try later, I've got Windows paint on here & think I've got a PSP prog somewhere. Quote Link to comment Share on other sites More sharing options...
simonb Posted June 25, 2006 Share Posted June 25, 2006 erm, changed the crank and camshaft seals 2 years ago when i did the belt (300TDi) and fitted them from the belt side of the case. To remove the timing case/chest on a 300Tdi, the sump has got to come off - see thread on black goo from a few days ago!!!! Quote Link to comment Share on other sites More sharing options...
white90 Posted June 26, 2006 Author Share Posted June 26, 2006 well it is now back together what started last monday as a oil leak turned into: transfer box off crawler box out injection pump off injection pump serviced new timing belt/seals new aux drive belt rear diff pinion seal blocked/now cleared breathers see how that goes for a while Quote Link to comment Share on other sites More sharing options...
