Lt77 rebuild
MECCANO
HELP!!! :lol:
I'm in the middle of replacing the bearings and synchro cones on an lt77 suffix E gearbox, using a master rebuild kit from Mr Croft
Reading through the manual as i go it says:
"It should be noted that the second gear synchromesh cone has larger slipper slots than the other synchromesh"
But not that i can see. :ph34r:
Ive compared the original cones in the box which all look the same, and similarly what is in the rebuild kit ( which are also the same).
I can only think im looking at the wrong slots?!?
Thanks in adavance
Chris
that'll be this thread -- LT77 gearbox rebuild
Guys, i think the larger slots only occurs on later boxes, to cure wear issues with the 2nd gear synchro. I found a picture of the differnc eon an sd1 forum that illustrates an lt77 rebuild.
The slots between the contact pads are about 1.5 times the size of the other synchros.
Chris
Hi as you will all realize i am new here so i hope i don´t upset anyone.
I have a LT77 52A Suffix D Long stick that was originally fitted to a V8 Range Rover -Question would this box fit in a V8 Defender?
Please guys Hope you can help me
yes it will fit fine but being an early suffix D it's not the strongest of LT7's,
Dave
