MECCANO Posted February 4, 2011 Share Posted February 4, 2011 HELP!!! I'm in the middle of replacing the bearings and synchro cones on an lt77 suffix E gearbox, using a master rebuild kit from Mr Croft Reading through the manual as i go it says: "It should be noted that the second gear synchromesh cone has larger slipper slots than the other synchromesh" But not that i can see. Ive compared the original cones in the box which all look the same, and similarly what is in the rebuild kit ( which are also the same). I can only think im looking at the wrong slots?!? Thanks in adavance Chris Quote Link to comment Share on other sites More sharing options...
Quagmire Posted February 5, 2011 Share Posted February 5, 2011 No idea Have you checked the thread in the tech archive? Quote Link to comment Share on other sites More sharing options...
western Posted February 5, 2011 Share Posted February 5, 2011 that'll be this thread -- LT77 gearbox rebuild Quote Link to comment Share on other sites More sharing options...
MECCANO Posted February 5, 2011 Author Share Posted February 5, 2011 that'll be this thread -- LT77 gearbox rebuild Guys, i think the larger slots only occurs on later boxes, to cure wear issues with the 2nd gear synchro. I found a picture of the differnc eon an sd1 forum that illustrates an lt77 rebuild. The slots between the contact pads are about 1.5 times the size of the other synchros. Chris Quote Link to comment Share on other sites More sharing options...
Quagmire Posted February 6, 2011 Share Posted February 6, 2011 nice one brother You all set for Friday? I have my TD5 gauges in (still using old binnacle and warning panel though for the time being). I can actually see how fast I'm going! Quote Link to comment Share on other sites More sharing options...
MECCANO Posted February 6, 2011 Author Share Posted February 6, 2011 As ready as i will ever be with the 2.25 pile of .... Given up on trying to tune it anymore. Glad to hear got it sorted and it works okay. Not sure on the status of the G-wagon yet, will find out tomorrow. Quote Link to comment Share on other sites More sharing options...
Spannerking Posted February 9, 2011 Share Posted February 9, 2011 Hi as you will all realize i am new here so i hope i don´t upset anyone. I have a LT77 52A Suffix D Long stick that was originally fitted to a V8 Range Rover -Question would this box fit in a V8 Defender? Please guys Hope you can help me Quote Link to comment Share on other sites More sharing options...
ashtrans Posted February 9, 2011 Share Posted February 9, 2011 Hi as you will all realize i am new here so i hope i don´t upset anyone. I have a LT77 52A Suffix D Long stick that was originally fitted to a V8 Range Rover -Question would this box fit in a V8 Defender? Please guys Hope you can help me yes it will fit fine but being an early suffix D it's not the strongest of LT7's, Dave Quote Link to comment Share on other sites More sharing options...
Spannerking Posted February 11, 2011 Share Posted February 11, 2011 yes it will fit fine but being an early suffix D it's not the strongest of LT7's, Dave Thanks for your help Kenny Quote Link to comment Share on other sites More sharing options...
