BillyH Posted March 13, 2011 Share Posted March 13, 2011 Excuse my lack of technical words to describe what I'd like to do, but hopefully I can convey my idea well enough... I swear at one point in my life I saw a 110 or a 90 with storage compartments built into the rear, where sideways facing seats would go. I'd like to install a similar cubby box to what's under the driver and passenger seats, in the back, inside those raised sides where the benches would go. A, can this be done? B, has anyone got photos of something like this? Thanks Quote Link to comment Share on other sites More sharing options...
reads90 Posted March 13, 2011 Share Posted March 13, 2011 Um if you do it to a 90 the you have the rear tyre in the way Spme of the older 109's vans used to have it in the back Quote Link to comment Share on other sites More sharing options...
western Posted March 13, 2011 Share Posted March 13, 2011 possible to use the Series LR parts 109 on the left rear wheel arch, but not the right as the fuel filler tube/hose is in the way. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 13, 2011 Share Posted March 13, 2011 Probably an ExMOD 110 you saw, with the storage lockers in the pannel behind the doors/in front of the rear wheels. Used for Jerry cans I think. Quote Link to comment Share on other sites More sharing options...
western Posted March 13, 2011 Share Posted March 13, 2011 reckon you saw the stowage in item 3 & 4 on page 828 as on some 110 hardtop or pick ups. don't know where the actual bin & lid is listed though, probably in the military 110 parts book. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 13, 2011 Share Posted March 13, 2011 You are not dreaming my old B reg 110 had a storage compartment in the back left I used to keep a split charged battery in there, it was covered by the same type of flap the front under seat lockers have, in fact I did wonder if I had been mistaken myself until I saw a 110 on ebay the other day with it showing. It would not work on the newer ones because of the way the single seats are mounted and it would only work under a bench seat. Jason. Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 13, 2011 Share Posted March 13, 2011 109s were fitted with a tool box in the rear end of the tub's left wheel arch. Some 110s had this, but it was soon deleted. Military 110s have jerrycan lockers in the sides of the tub ahead of each wheel arch. The early types had flat doors with two over-centre catches, while Wolfs have bevelled doors with an antiluce. The latter can be bought from Foleys. Lanybox make some aftermarket storage systems to fit the same space. None of these items can be fitted to a 90. Barebox and Mobile Storage Systems make internal storage chests that fit the tops of the wheel arches. These will fit 90s and 110s and also Series vehicles. Quote Link to comment Share on other sites More sharing options...
BillyH Posted March 13, 2011 Author Share Posted March 13, 2011 Thanks all I will certainly be pushed for space, it's just that I don't want to buy one of those lockers which slides into the loadbay, as I am not a big fan of that look, nor do I need that much space. I just need somewhere to keep some extra tools and a battery for other electronics to connect to. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 13, 2011 Share Posted March 13, 2011 For a second battery, there is space in the battery box, unless you've put other things in there? Is yours a TD5? if so isnt there space under the drivers seat for tools etc? Quote Link to comment Share on other sites More sharing options...
LinDens90XS Posted March 13, 2011 Share Posted March 13, 2011 TD5's have the electronics in there with extra fuses and relay's, so need to be careful what you put in there. I have my spare bulbs and fuses in the handy plastic container velcro'd to the front. Think you would need to fabricate a shallow tray suspended over the top to put anything heavy in there? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 14, 2011 Share Posted March 14, 2011 Ah OK, I didnt know it was all over the bottom. Being an '84, mine is somewhat devoid of extra ECUs and electronics! Thankfully!!! Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 14, 2011 Share Posted March 14, 2011 Yes it's possible. I've done it to my Defender 110 both sides. Go to www.landroveraddict.com and do a search Not only are the pictures there but the drawings with all the dimensions as well HTH Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 14, 2011 Share Posted March 14, 2011 If you have a 110, you may have that rear tool box just inside the left side of the rear door. If not, you can retrofit one from a broken 109, but you will have to rivet it to the rear wing, which won't be pretty. If you don't hate chequer plate too much, you could use some of that to hide the rivets. As I said, Barebox and Mobile Storage Systems have units which fit inside the tub atop the wheel arches and need no externally visible drilling or alteration, just bolts through the top of the wheel arches.. Up front, you may have a tool box under the drivers seat. It's not standard on early models, but YRM sell tool boxes that will fit. You'd need to fit the same type of lid and catch as you have on the battery compartment on the left side. You could also look into fitting a Series 24V style battery tray and lid which sits in the cavity between the two front seats above the transmission, using an otherwise void space. This would prevent the fitting of a cubby box if you have a battery in the re, but if you fit a second battery to the existing battery compartment (should be possible), you could use the 24V tray as a tool box and have a standard lid and either a seat or cubby box above it. Quote Link to comment Share on other sites More sharing options...
BillyH Posted March 14, 2011 Author Share Posted March 14, 2011 As said, there's no room under my seat, as the ECU is in there. I tried the passenger side, but the battery is literally 5mm too big to squeeze in. I think I need to take the other battery out, then put the new in and then replace the original Tetris style I had a look at those Bareboxes, but I really want to keep the sides as they are, as I often have people sat in the back and space is limited enough when I've got a tonne of kit in the back too...! Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 14, 2011 Share Posted March 14, 2011 How about a simple galvanised sheet steel cradle and mudshield to carry the battery under the tub wheel arch, ahead of the rear wheel, and a tool box that fits the void under the centre seat/cubby box? Quote Link to comment Share on other sites More sharing options...
reads90 Posted March 15, 2011 Share Posted March 15, 2011 As said, there's no room under my seat, as the ECU is in there. I tried the passenger side, but the battery is literally 5mm too big to squeeze in. I think I need to take the other battery out, then put the new in and then replace the original Tetris style I had a look at those Bareboxes, but I really want to keep the sides as they are, as I often have people sat in the back and space is limited enough when I've got a tonne of kit in the back too...! Yeah it is always a bit tight but you can get two into the battery box. This is a picturs of my 90 . But my 110 has two bigger batteries in the try. but dont have a pic of that at the moment Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 15, 2011 Share Posted March 15, 2011 Do what I did. Remake the battery box. Simple.I have the normal Land Rover battery for the engine. A Numax 110 amp battery. Proper jump leads. Two fuse boxes. Numerous relays in there. I can take either battery out without disturbing the other one. Quote Link to comment Share on other sites More sharing options...
mrtod Posted March 15, 2011 Share Posted March 15, 2011 Hi, have you seen the product made by LandieBox - LandieBox Tod Quote Link to comment Share on other sites More sharing options...
bobinof Posted March 28, 2011 Share Posted March 28, 2011 Hi, have you seen the product made by LandieBox - LandieBox Tod they have some really good ideas ther at landiebox, i think i might try and make some for my 110 Quote Link to comment Share on other sites More sharing options...
Flux Posted June 14, 2011 Share Posted June 14, 2011 Yes it's possible. I've done it to my Defender 110 both sides. Go to www.landroveraddict.com and do a search Thanks but what would be the search words and is it in the forums section Quote Link to comment Share on other sites More sharing options...
