landroversforever Posted March 29, 2011 Author Share Posted March 29, 2011 I cant get to the back of the fusebox very well Mo. I'd rather add a connector than risk damaging another with the soldering iron. Even if I was to solder, what size wire do I need? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 29, 2011 Share Posted March 29, 2011 Same as what was there before And yes, solder it ya lazy git Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 29, 2011 Author Share Posted March 29, 2011 I'm ordering wire online, so need to know a mm2? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 30, 2011 Share Posted March 30, 2011 Unscrew the fusebox from the bulkhead Ross, it's only 2 bolts. Good job you don't do this for a living, Ross, you've made a 20 minute job last 5 days !!!!!!!!!! Your fog light is pulling only a couple of amps so 1mmSq would be fine but get 2mmSq if you are feeling flush. You'll also need to fit a fire suppression system for the tap connectors HTH Mo Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 30, 2011 Author Share Posted March 30, 2011 It's already off the bulkhead Mo . The wires going in are very short between bulkhead and fusebox... Let's hope I get the right wire! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 30, 2011 Share Posted March 30, 2011 you've made a 20 minute job last 5 days !!!!!!!!!! And 30 posts God help us if his radio stops working Quote Link to comment Share on other sites More sharing options...
crclifford Posted March 30, 2011 Share Posted March 30, 2011 Ahh, radios easy...took me several weeks of no radio, before i pulled it out and spotted that the earth connection had come apart......again!!!!!!! You'd of thought i would of learnt from when i changed the original radio which had stopped working, for the same reason!!!!! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 30, 2011 Author Share Posted March 30, 2011 And 30 posts God help us if his radio stops working You say that... radio has been intermittent since I filled it with water at Hogmoor Quote Link to comment Share on other sites More sharing options...
