Plenum pot help pls
ashtrans
Do you mean "is there a 0-5v signal coming from this" or "is it possible to use this to give a 0-5v signal to something"?
It's just a potentiometer, the 5v comes from the ECU, if the ECU gave out 10v you'd get a 0-10v signal from it instead :unsure:
You as normal are right but you know what we meant. Have you been at the pedant pills? tongue.gif
sorry I am not sure, whatever was in the V8 50th defenders, was 4.0, now 5.0, I think it's on the same injection system but engines aren't my strong point !
Dave
The 50th uses the same TPS as the P38a GEMS (up to 2000). They seem pretty lineair.
