Frax Posted April 30, 2011 Share Posted April 30, 2011 Do any of you have an alternative to the seals that Land Rover use to seal the seat box to rear bulkhead also the floor plates and seat box to floor. Would silicon or Tiger seal do the same job or is there a rubber strip that you can buy that is sticky on one side just in case they need to be removed at some point. Regards Frax Quote Link to comment Share on other sites More sharing options...
Buzza Posted April 30, 2011 Share Posted April 30, 2011 Do any of you have an alternative to the seals that Land Rover use to seal the seat box to rear bulkhead also the floor plates and seat box to floor. Would silicon or Tiger seal do the same job or is there a rubber strip that you can buy that is sticky on one side just in case they need to be removed at some point. Regards Frax Sure to find something here : http://www.tapes-direct.co.uk/index.php?main_page=index&cPath=142&src=adwords&gclid=COSZ7pSQxKgCFchO4QodE1KAqA Steve Quote Link to comment Share on other sites More sharing options...
pat_pending Posted April 30, 2011 Share Posted April 30, 2011 I used flashing tape from wickes. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 30, 2011 Share Posted April 30, 2011 Seal ?? What seal ??? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 30, 2011 Share Posted April 30, 2011 The rubber strip between the seat box and rear tub/other panels. I'm just using weatherstrip on the new build. Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 30, 2011 Share Posted April 30, 2011 Draught excluder tape from a DIY or hardware shop would be best. Silicone is messy and would make removal of the seat base difficult, while PU adhesive like Tiger Seal would make removal impossible. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 30, 2011 Share Posted April 30, 2011 Bought a roll of single sided foam one inch wide tape from the Bay of Evil last time Quote Link to comment Share on other sites More sharing options...
Frax Posted April 30, 2011 Author Share Posted April 30, 2011 Thank you for all the replies; I think I will have a look for some rubber tape. Dont think Tiger Seal would be a good idea thinking about it. Knowing my luck if I stick it down I will need it out & if I dont stick it down I will never need it out. Frax Quote Link to comment Share on other sites More sharing options...
