tonko007 Posted June 5, 2011 Share Posted June 5, 2011 Hi all again Can you please help me. While out at a car boot sale in a field. I thought it would engage the diff lock as it had not been used in a while. After a couple of attempts i finally got it in never had ant problems before but hey. Anyway just before getting onto the main foad i tried to put in in the unlocked position and it was rock solid went up to low range and neutral but would not slide across. Have i proper buggred it or is it an easy fix plz plz help many thanks paul Quote Link to comment Share on other sites More sharing options...
Quagmire Posted June 6, 2011 Share Posted June 6, 2011 If the field was not slippery and you made any significant turns then you may have some transmission "wind up" from having the diff engaged. Try reversing a bit before trying the diff lock lever again. Quote Link to comment Share on other sites More sharing options...
SPendrey Posted June 6, 2011 Share Posted June 6, 2011 Yep, I'd second what Quagmire says... if it goes into lock it'll probably come out again with some wiggling, but if you reverese at a fair pace then try it'll come out easier. Better still, reverse in a field to allow a little tyre slip! Scott Quote Link to comment Share on other sites More sharing options...
Richard Mills Posted June 6, 2011 Share Posted June 6, 2011 Hi There, If diff lock hasn't been used in a while it will almost always lock on. If you get under it with the WD40 and spray the linkage it will work fine again for about a year, then it will need doing again. Quote Link to comment Share on other sites More sharing options...
bear Posted June 7, 2011 Share Posted June 7, 2011 Hi, Agree with the WD40 but my old 200tdi did the same thing and turned out to be the clevis pin having worked loose having lost its retaining clip. You'll see if it's this whilst your underneath with your can of WD40 Regards Quote Link to comment Share on other sites More sharing options...
Silverbake Posted June 8, 2011 Share Posted June 8, 2011 Diff lock has seized solid a couple of times on my 3.9 V8. After trying all the forward/reverse tricks I ended-up stripping out all the centre console in the cab to expose the top of the selector box, then simply forcing the lever back into place. Second time I had to use a gentle tap with the sledge hammer: the end of the horizontal selector pin (sorry - not very technical) had siezed in the left hand side of the box. Having done it all once and thought it was sorted for ever, the second time I drowned the whole shebang in transmission fluid before reassembly. Now I make a point of engaging and disengaging whilst driving at least once a week (making sure I'm on a straight bit of road) to keep it all free and happy. So far so good. Quote Link to comment Share on other sites More sharing options...
tonko007 Posted June 15, 2011 Author Share Posted June 15, 2011 Hi guys tried the reversing didnt work to got it home and soaked everywhere i could see in wd40 and hey presto it popped out thanks for the advice paul Quote Link to comment Share on other sites More sharing options...
western Posted June 15, 2011 Share Posted June 15, 2011 get some spray grease like the stuff used on motorcycle chains, it'll stay in place & give better protection than WD40. Quote Link to comment Share on other sites More sharing options...
