reb78 Posted August 11, 2011 Share Posted August 11, 2011 I've got a defender TD5 transfer box to replace the leaky box on my 1989 110. Its all fine, but the new box has an additional sensor and set of wires that the old one doesnt (i think - the old ones still on the truck). See the pics below: Are these a problem for me to fit this box to my 110? Do i need to do anything with them? Thanks Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 11, 2011 Share Posted August 11, 2011 Pretty sure that's the lock-out solenoid, and it needs removing... did it come out of an auto? Quote Link to comment Share on other sites More sharing options...
cosecon Posted August 11, 2011 Share Posted August 11, 2011 I think it is IGM100000 "LOW ratio detect." Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 11, 2011 Author Share Posted August 11, 2011 Pretty sure that's the lock-out solenoid, and it needs removing... did it come out of an auto? I dont know. I guess the chances are low since it came out of a defender - its a 1.4:1 ratio (or so the sticker says). Hope this isnt going to be complicated! I was in a hurry when i picked it up, so didnt pay much attention otherwise i would have queried it. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 11, 2011 Author Share Posted August 11, 2011 I think it is IGM100000 "LOW ratio detect." That sounds like it would be less trouble than a lock out solenoid! I guess i can just leave that as is?? I wondered if it was anything to do with newfangled things like traction or cruise control? Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 11, 2011 Author Share Posted August 11, 2011 I think it is IGM100000 "LOW ratio detect." I think you are right - just found this link with an image: http://www.brit-car.co.uk/product.php?xProd=122627 I guess that can be left present but disconnected? I i want an extra warning light at some point i suppose i could wire it up! Quote Link to comment Share on other sites More sharing options...
cosecon Posted August 11, 2011 Share Posted August 11, 2011 I think it is just a sensor (item 22), I would not mind but just wait for any grown up to answer.... Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted August 11, 2011 Share Posted August 11, 2011 It's the sensor that tells the engine ECU that you're in low ratio, so that it can re-map the throttle response as such. Quote Link to comment Share on other sites More sharing options...
cosecon Posted August 11, 2011 Share Posted August 11, 2011 It's the sensor that tells the engine ECU that you're in low ratio, so that it can re-map the throttle response as such. This could be an interesting input for Megasquirt!!!! Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 11, 2011 Author Share Posted August 11, 2011 It's the sensor that tells the engine ECU that you're in low ratio, so that it can re-map the throttle response as such. So its ok to just leave it disconnected? One other thought i've just had about this box is that i need to check its not an LT230Q as i dont think my overdrive input gear will work with that from what i've just read whilst researching this switch! Thats going to bug me till i get home now and can look at the serial number! Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted August 11, 2011 Share Posted August 11, 2011 Yeah, should be fine. LT230Qs were definitely around in the Td5 days, so yes worth checking! Quote Link to comment Share on other sites More sharing options...
mickeyw Posted August 11, 2011 Share Posted August 11, 2011 As Retroanaconda has said - a low ratio detect switch, not needed on pre-Td5 trucks. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 11, 2011 Author Share Posted August 11, 2011 Thanks all. Thats a releif! I've just checked the serial number and it is: I'm presuming the badly formed figure at the start is a '5' - the 57D corresponds with a 1.4:1 ratio according to Ashcrofts and from this number, i dont think this is an LT230Q - the manual i have states that the LT230Q are prefixed with 36D, 37D, 38D & 40D (the first two are disco units and the second two are defender). Having said that, can anyone confirm that i am correct with this? - my LT230T manual isnt old enough to cover this prefix so i cant confirm it from that! Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 11, 2011 Author Share Posted August 11, 2011 Just dug out my Rave CD and the LT230T manual on there has 57D listed as the defender version of the box. LT230Q is as stated above. Looks like it should be ok with my overdrive, but will check the input gears are identical tooth wise when i have them side by side. Quote Link to comment Share on other sites More sharing options...
western Posted August 11, 2011 Share Posted August 11, 2011 Microcat tells me a 57D prefix is a LT230 1.4.1 ratio for 4 cylinder engined vehicles, so it's NOT a LT230Q. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 12, 2011 Author Share Posted August 12, 2011 I guess the other good thing about this box is that it comes with the attachment to convert my speedo to a TD5 version. Not a job for this weekend - the old speedo drive will be going in, but a [project for the future (as if there isnt enough to do on it!) Quote Link to comment Share on other sites More sharing options...
mickeyw Posted August 12, 2011 Share Posted August 12, 2011 AFAIK all LT230 trf boxes can accommodate the electronic speedo transducer required for Td5 Speedo. It has the same fitment into the box as the old speedo drive cable. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 12, 2011 Author Share Posted August 12, 2011 AFAIK all LT230 trf boxes can accommodate the electronic speedo transducer required for Td5 Speedo. It has the same fitment into the box as the old speedo drive cable. I think you are right. I meant that this box has come with the transducer to attach the wires to, so its saved me the hassle of sourcing one later. Quote Link to comment Share on other sites More sharing options...
western Posted August 12, 2011 Share Posted August 12, 2011 AFAIK all LT230 trf boxes can accommodate the electronic speedo transducer required for Td5 Speedo. It has the same fitment into the box as the old speedo drive cable. Correct, the green transducer just bolts straight on, uses the same drive gear as the cable driven speedo. Quote Link to comment Share on other sites More sharing options...
