can it be done pto on a disco 1
twizzle
hi all
Can it be done pto mec winch on a disco 1 you see them on 110/90 but not on a disco
i have the pto what is on my 2a with LT77 gearbox but would one fit to the disco and how would you fit A: the winch(H14) B:the sharfts getting around the 300tdi exhaust C:the pto
anybody
:blink: TWIZZLE :blink:
You'll need to check to see if your transfer case has PTO splines. I've heard they were left off on some Discos but have no idea which ones. The shafts, well you'll need clearance depending on where you want to run them it probably means a plasma cutter and some fabrication. PTO hydraulic drive and H12/14 on the other hand is much easier to deal with.
It should fit to a disco 1 transferbox, thats what I run for my PTO. There is plenty of space past a 300 tdi exhaust, but the ears that come of the mounts to fit to the gearbox might be in the way. I did away with these because I have an LT77S box. the rest can be solved with a bit of fabwork.
Post a piccy when youre done.
Daan
