auto box wont change gear
mudmagnet
hi i have a disco 300tdi auto that i only use as my off road toy
today i went to use it and it will go into reverse and into drive but it wont change up the gears, so i am driving around in first gear
i have checked the oil level and thats ok and the oil is clear red
any ideas please
Mudmagnet, read about my woes in not being able to select reverse, -- the thread in in this section --- the immoral of the tale is not to let your LR stand for extended periods of time, you will need to flush the crud out of the ZF with a couple of oil and oil filter changes, and then to use it on a regular basis
found out what it was it was a stuck kickdown cable, i have disconnected the cable from the engine bay end and pushed it back through and all works fine now
except no kickdown, which isnt really going to be missed on a 300 tdi
glad it was an easy fix as im marshaling today
cheers
