WHO4 MUD Posted December 19, 2011 Share Posted December 19, 2011 just driven back to house and need to out again but its not starting fuel pump is coming on glow plugs light is coming on checked all fuses under seat and in the dash all good started unplugging and plugging things back in hasent made a difference. havent unplugged and plugg in, in the engine bay yet. really the started moter isnt doing the bussiness. does any one know which relay (if a relay does control the start moter wich one it is. any idears would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
WHO4 MUD Posted December 19, 2011 Author Share Posted December 19, 2011 ok so I've left it for a good half hour and now the glow plug light Isn't coming on Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 19, 2011 Share Posted December 19, 2011 How's your battery's health? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 19, 2011 Share Posted December 19, 2011 Is the starter motor turning at all? if not then maybe have a look at the earth from the ECU. Is the starter solenoid clicking but its not turning over? if so then the contacts in your solenoid are favourite. Quote Link to comment Share on other sites More sharing options...
matthew74 Posted December 19, 2011 Share Posted December 19, 2011 If the battery drops below about 10.5 volts it wont start. Mine did this if i hadn't driven it for a few days, due to a duff battery. Quote Link to comment Share on other sites More sharing options...
WHO4 MUD Posted December 19, 2011 Author Share Posted December 19, 2011 just checked battery its 12.somthing so its ok there is no clicking on the solenoid front and the alretnator isnt turning over sorry should have made that clear to start with im not shore ive seen an earth for the ecu but will have a gander for it Quote Link to comment Share on other sites More sharing options...
101sean Posted December 19, 2011 Share Posted December 19, 2011 Healthy battery should be around 13.4 volts, reckon yours is duff. They go from working to dead quickly in a Td5, like most modern electronically controlled engines they need full volts to work. Mine wouldn't start recently, trigger wire on to starter was solenoid was manky and loose. Quote Link to comment Share on other sites More sharing options...
WHO4 MUD Posted December 20, 2011 Author Share Posted December 20, 2011 Td5' s up and running again it was the trigger wire on starter moter, some 120 grit sand paper and a tooth brush sorted it out. who needs a nano com when you got lr4x4, mega Quote Link to comment Share on other sites More sharing options...
