Boydie Posted May 5, 2012 Share Posted May 5, 2012 On a friends series 1 (auto with A/C) there are two what apear to be temperature probes in the thermostat housing, one has a green twin wire connector the other green, again twin wires, can anyone shed a light on what these two do? They are not the temperature guage, that is a smaller 1/8 BSP probe in the side of the housing with a single wire, these two are under the alloy bend. My series 1 hasnt got them, only blank plugs Quote Link to comment Share on other sites More sharing options...
Boydie Posted May 5, 2012 Author Share Posted May 5, 2012 oops forgot to add its a 300Tdi, non electronic Quote Link to comment Share on other sites More sharing options...
chadler Posted May 5, 2012 Share Posted May 5, 2012 They are the thermostatic switches for the a/c I believe, although I'm sure someone will be along soon to add a bit more detail. Quote Link to comment Share on other sites More sharing options...
fozsug Posted May 5, 2012 Share Posted May 5, 2012 (edited) For the air con fans ^^^^^^^^ Snap!! Edited May 5, 2012 by fozsug Quote Link to comment Share on other sites More sharing options...
SPendrey Posted May 5, 2012 Share Posted May 5, 2012 That's right... The A/C fans switch on at something like 105 degrees if I recall. Quote Link to comment Share on other sites More sharing options...
western Posted May 5, 2012 Share Posted May 5, 2012 http://forums.lr4x4.com/index.php?showtopic=37904 might help Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 5, 2012 Share Posted May 5, 2012 Close - one of the switches is for the AC auxilliary fans if the viscous fan isn't managing by itself, and the second is an AC cut-out trigger to kill the AC and ease the engine load if the combined cooling of the viscous and electric auxilliary fans still can't cope. Quote Link to comment Share on other sites More sharing options...
Boydie Posted May 6, 2012 Author Share Posted May 6, 2012 Thanks guys, it seems that some Series 1 Discos were supplied without A/C and it was added after sale as a dealer option, so these sensors were never fitted. Mine has the sensor for the fans but no sensor to cut out the compressor, anyway thanks for your infomation, it helps figure things out. Quote Link to comment Share on other sites More sharing options...
teabag Posted May 6, 2012 Share Posted May 6, 2012 http://forums.lr4x4.com/index.php?showtopic=37904 Quote Link to comment Share on other sites More sharing options...
